SSH proxy not working
Hi All,
I used this instructions: SSH Proxy Security to configure ssh proxy, but without success.
How it works:
Putty show me login, but after I write there some login, it give me error message: Network error: Software caused connection abort.
Logs on F5 show me this: ssh_serverside_auth_fail Real server public key" in the configuration does not match the private key of the backend server",
I have already checked public key from backend server.
I want only authentication via username and password via ssh proxy.
Thank you
i assume access works without the F5 SSH proxy?
which part of that manual did you follow, the part at: “Defining SSH proxy password or keyboard interactive authentication”?
you follow all the information mentioned there?
Hi boneyard,
I guess yes.
I started with this:
Proxying SSH traffic with an SSH Proxy profile - finished with 11 step.
Creating an SSH virtual server with SSH proxy security- finished with 8. step
Attaching an SSH proxy security profile to an existing virtual server- finsihed with 4. step.
Defining SSH proxy password or keyboard interactive authentication - finished with 9. step.
From backend server I use public key from root/.ssh/id_rsa.pub and copy it without email addres, which was on the end of text, to F5 Real Server Auth Public key.
Thank you
You have to use /etc/ssh/ssh_host_rsa_key.pub instead of root/.ssh/id_rsa.pub.
And as it written in docs to v.15 - Make sure not to include the trailing comment.
I did it and now I not receiving this error message in log but I’m still cant connect - after I’m entered the password it hangs up and then closed -_-
Hi Dimitry,
I have already tried to change public key with this: /etc/ssh/ssh_host_rsa_key.pub but still same, should I restart some process maybe ?
Thank you
Generally not, you only need to commit.
Do you still get the same error in log ?
After I inserted the correct public key I got nothing in log so my troubles seems to be related with PAM.
I have still same logs on F5. I still receiving login prompt: "login as:", I can also write there, but when I push enter I´m receiving Network error.
Thank you
Your public key have to look like:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCziS6yavPpFuRjLP9hzRiEBcVgLDynoWqNMuwCrOREkSiDqWqFRrydFCGy6Z1WwwJuDMIw5h3sIuqtOo78zd6pBabXpj0QLUyLtGx80Oe3vInpwxvG2/YX9KaGjofkasZJ+tOqoOe5QscnUYr7Iw6CEuo2dBVIZyL/o1IyTvDfL8+yXO4vPzadmL0gvV1F56feRVsCF0HUrhWwdrQ6CpIpX6acsY0HayrhOGPmVF4qRz7fLySHJ5XQz5IKXJRNHJEbXx2tiV1TuQlhz8gOMqMp2IiSqyKDcUTk2Oy0fPYkNAWPlifq7GplYkit85EL5UCgtHf595rqibOQJWFAAzHF
It have to be one long string, without any newlines. And without “email” at the end of the string.
If all correct you can try to find HostKey directives on your backend ssh server config and comment out all except the rsa, like this:
HostKey /etc/ssh/ssh_host_rsa_key
#HostKey /etc/ssh/ssh_host_ed25519_key
Of course you have to restart ssh server after you make changes.
Hi Dmitry,
Thank you fro answer, problem was, that I did not commented another HostKeys. Do you have any idea, why it didn’t work with uncomennted another HostKeys ? because on F5 there was specified ssh-rsa.
Thank you
I think this is because F5 doesnt support ECDHE ssh keys (look at “Current limits of SSH Proxy” at the beginning of chapter about SSH Proxy ).
BTW does it work with putty for you?
It hangs up with putty for me after entering the password. WinSCP and MobaXterm works fine, so its look like the putty issue (not PAM as i assumed before).
For me, it works for putty too.
