we’ve 2 VS for SSH ( Delinea Secret Server ), Type Performance L4, NAT: AutoMap, an appropiate L4 tcp Profile and so on.
If I try the connection with ssh -vvv admin@service.com. the connection gets established, but I don’t get the challenge for the Fingerprint and no Password Prompt.
A tcpdump looks fine, no Resets or else.
I can ssh to the Pool Members from a Linux Client and from the F5 CLI without Problems.
So I think the F5 drops anywhere the Key Exchange/Fingerprint.
Using a Performance Layer 4 Virtual Server may well bring PVA into the equation which would impact the tcpdump traffic captured so you could well be missing something important.
I would tweak the tcpdump output though as shown below (I have appended the ‘p’ to the command so that both sides (client and server) are captured) which might help show where the issue is:
So that would suggest that the F5 devices are Virtual then at a guess.
Not really important either way - PVA is not in the picture so it can’t affect the tcpdump output so I would run the tcp command above and see what it returns. Since it captures both the client and server traffic I am hoping that will shed a bit more light on where things are not working.
Noticed you had some suggestions and wanted to check if you had a solution to update your post? If not and you need additional assistance let us know so we can look at what options would be available to assist you.
sorry, that I’ve ignored the last posts, but for 99% the Problem is on the poolmember: an identical Test-VIP is working after Software-Update of the Pool-Member, so I guess, it’s not a F5 Problem
