ssh: Common Criteria mode initialized
I setup a new F5 and I am trying to SSH to an existing F5 but from the new F5 I get "
ssh: Common Criteria mode initialized"
I ran the command “tmsh list sys db security.commoncriteria” and it is set to false on both F5.
I checked the sshd properties and both F5 have the following
description none
fips-cipher-version 2
inactivity-timeout 6000
include "Ciphers aes256-ctr,aes256-gcm@openssh.com,aes128-gcm@openssh.com,aes128-ctr
KexAlgorithms ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521
MACs hmac-sha2-256-etm@openssh.com,hmac-sha2-256,hmac-sha2-512-etm@openssh.com,hmac-sha2-512"
log-level info
login enabled
port 22
what am i missing
can you try to ssh with the -vvv option. This will tell you which ciphers you’re using and what the F5 is using.
You might need to restart the SSH daemon ‘save config’ and reboot for the less secure mode to take effect (thats a guess)
Hello @steven_normole
Noticed it has been a bit since you received a response and wanted to encourage you to respond with an update if you were able to solve or if you need additional assistance.
Melissa
