regexp to parse querystring parameters
I am trying to get a list of querystring parameters from the URI. There’s an example iRule that does this here:
http://devcentral.f5.com/wiki/default.aspx/iRules/URIInterrogation.html
The relevant code is:
set namevals [split [HTTP::query] "&"]
 for {set i 0} {$i < [llength $namevals]} {incr i} {
 set params [split [lindex $namevals $i] "="]
 set pnum [expr $i+1]
 log local0. "Param\[$pnum\]: [lindex $params 0]"
 log local0. "Value\[$pnum\]: [URI::query [HTTP::uri] [lindex $params 0]]"
That code works fine, but it seems like this would be more efficient as a regexp, or even a foreach. Can anyone think of a better way to implement this?
I’d think this looping with string commands would be more efficient than a regex. A foreach loop would probably be about the same. You could test these options using the timing command (Click here).
If you are trying to retrieve the value for a specific parameter, you don’t have to loop through each parameter name. You can just use URI::query:
URI::query [HTTP::uri] “param_name”
Aaron
Makes sense. This is related to my other post - I’m stuck in the TCP stream without an HTTP profile since I am tunneling non HTTP traffic over HTTP, so I’m forced to do all my HTTP parsing manually (joy of joys).
Jim
If you have any string in the format of ?name1=value1&name2=value2, you can use URI::query to parse the value of any of the parameters:
set my_uri “?action=login&pref=2”
log local0. “[URI::query $my_uri “action”]”
This would output “login”. If you’ve already removed the question mark when parsing the URI string, you could prepend it:
set my_uri “action=login&pref=2”
log local0. “[URI::query “?$my_uri” “action”]”
Aaron
