Can you please let me know how can I accomplish the below requirement with an iRule.
Any requests that use any method and have “cs.exe” or “llisapi.dll” in the URI and also have a query string or form post variable called “fInArgs” that contains the string “%3D%23” should return 403 Forbidden.
Hi @abhinay ,
As @mihaic figured out his iRule , it should meet your requirements.
I want to add only this part to specify the ( Query string name and value ) in Requests
you can add to @mihaic iRule :
[URI::query [HTTP::uri] "fInArgs"] equals "%3D%23"]
#add this part after and operator in iRule instead of ([string tolower[HTTP::query]...)
it is only to be more specified
I only tested that the syntax is ok. The functionality, no. Did not have time yet.
Here is the irule with the variable also:(not functional tested):
ltm data-group internal example_uri_1 {<br> records {<br> cs.exe { }<br> llisapi.dll { }<br> }<br>type string<br>}<br><br>when HTTP_REQUEST { <br> if { ([matchclass [string tolower [HTTP::uri]] contains example_uri_1]) and ( [HTTP::query] contains "%3D%23") }{<br> HTTP::respond 403 content "You don't have authorization to view this page. Access Denied" noserver Content-Type text/html Connection Close Cache-Control no-cache<br><br> } <br>}<br><br><br>when HTTP_REQUEST_DATA {<br><br> if { [HTTP::method] equals "POST" }{<br># Extract the entire HTTP request body and escape it to become a HTTP::uri string (for easier parsings) <br> set http_request_body "?[HTTP::payload [HTTP::header value "Content-Length"]]"<br># Try to parse type value from the HTTP request body.<br> if { [URI::decode [URI::query $request_body fInArgs]] equals "%3D%23" } {<br> log local0. "fInArgs : $fInArgs"<br> HTTP::respond 403 content "You don't have authorization to view this page. Access Denied" noserver Content-Type text/html Connection Close Cache-Control no-cache <br>} <br>} <br>}
Hello @abhinay ,
I’ve recently implemented a similar check on one of my customers. Try the following:
if { [HTTP::uri] contains "cs.exe" || [HTTP::uri] contains "llisapi.dll" }{
if { [URI::decode [HTTP::query]] contains "flnArgs" }{
set value [findstr [URI::decode [HTTP::query] "flnArgs" 7 &]
if { $value contains "#=" }{
log local0. "violation detected: flnArgs=$value"
HTTP::respond 403 content "Forbidden"
# if URI does not contain parameter, I capture traffic (up to 1MB) and perform this check again on full payload
if {[HTTP::header "Content-Length"] ne "" && [HTTP::header "Content-Length"] <= 1048576}{
set content_length [HTTP::header "Content-Length"]
} else { set content_length 1048576 }
if { $content_length > 0} { HTTP::collect $content_length ; set checkpayload 1 }
if { $checkpayload }{
set cleanpl [URI::decode [HTTP::payload]]
set value [findstr $cleanpl "flnArgs" 7 &]
Notice that I’m decoding URI so %3D%23 will be normalized to #= , this match is more effective IMO
<a href="javascript:void(0)" data-lia-user-mentions="" data-lia-user-uid="72830" data-lia-user-login="mihaic" class="lia-mention lia-mention-user" rel="nofollow noopener noreferrer">mihaic</a>, URI along with query that contains "%3D%23" combination is working but the below payload with the body that contains %3D%23 doesnt seem to work. As we are decoding the query I tried "=#" too but no luck.<br>Any suggestions would be appreaciated<br><br>
I’m noticing this code is missing an HTTP::collect statement, so HTTP_REQUEST_DATA event will never be fired. @abhinay Have you checked my other response yet?
hi @CA_Valli , I did check your response and tried to implement it but was getting syntax errors. I think a } bracket and ] bracket were missing. Added it but still getting the error. I will have to check the syntax once.
Also there are 2 requirements.
1. URI contains cs.exe or llisapi.dll in the URI and query contains “%3D%23” - This is working
2. Request body value “fInArgs” which contains “%3D%23” - This is not working
Oops, you’re right - I’ve lost a couple parenthesis in the copy/paste, also #= should be inverted to =#
Sorry! Fixed below.
set value [findstr [URI::decode [HTTP::query]] "flnArgs" 7 &]
if { $value contains "=#" }{
one more little thing I just noticed from logs, you see I’m specifying “flnArgs=%3D%23” when making the request but $value is " ==# " -- that’s because at line #5 and at line #24 I’m not escaping the first “=” match (before the %3D).
If you want to escape it, change 7 to 8 in said lines. Otherwise, it will ALSO match anything that contains “flnArgs=%23” since the first “=” character is the equivalent of %3D
@abhinay please share how you test in postman.
I’ve tried and it works if the POST body is raw type and looks like this : fInArgs=%3D%23
This is what rules I am using:
when HTTP_REQUEST { <br> if { ([class match [HTTP::uri] contains example_uri_1]) and ( [HTTP::query] contains "%3D%23") }{<br> HTTP::respond 403 content "You don't have authorization to view this page. Access Denied" noserver Content-Type text/html Connection Close Cache-Control no-cache <br> log local0. "deny URI: [HTTP::uri] query:[HTTP::query]"<br> }<br> if {[HTTP::method] eq "POST"}{<br> # Trigger collection for up to 1MB of data<br> if {[HTTP::header "Content-Length"] ne "" && [HTTP::header "Content-Length"] <= 1048576}{<br> set content_length [HTTP::header "Content-Length"]<br> } else {<br> set content_length 1048576<br>}<br># Check if $content_length is not set to 0<br> if { $content_length > 0} {<br> HTTP::collect $content_length<br>}<br>}<br>}<br>when HTTP_REQUEST_DATA {<br><br> if { [HTTP::method] equals "POST" }{<br># Extract the entire HTTP request body and escape it to become a HTTP::uri string (for easier parsings) <br> set http_request_body "?[HTTP::payload]"<br> log local0. "http payload: $http_request_body"<br># Try to parse type value from the HTTP request body.<br> if { [URI::query $http_request_body fInArgs] equals "%3D%23" } {<br> HTTP::respond 403 content "You don't have authorization to view this page. Access Denied" noserver Content-Type text/html Connection Close Cache-Control no-cache <br>} } <br>}
if you use application/x-www-form-urlencoded you will have to match this “%253D%2523”
if { [URI::query $http_request_body fInArgs] equals "%253D%2523" } {<br>HTTP::respond 403 content "You don't have authorization to view this page. Access Denied" noserver Content-Type text/html Connection Close Cache-Control no-cache <br>}
or use URI::decode :
if { [URI::decode [URI::query $http_request_body fInArgs]] equals "%3D%23" } {<br>HTTP::respond 403 content "You don't have authorization to view this page. Access Denied" noserver Content-Type text/html Connection Close Cache-Control no-cache <br>}
and if it is a form-data:
set varB [findstr [HTTP::payload] "fInArgs"]<br>if { $varB contains "%3D%23" } {<br> HTTP::respond 403 content "You don't have authorization to view this page. Access Denied" noserver Content-Type text/html Connection Close Cache-Control no-cache <br> }
@mihaic , small change in URI from “cs.exe” to “/cs”. I dont mind having two different iRules for GET and POST.
Below GET is working abosultely fine
ltm data-group internal uri_list {
records {
/cs { }
llisapi.dll { }
type string
if { ([matchclass [string tolower [HTTP::uri]] contains uri_list]) and ( [HTTP::query] contains “%3D%23”) }{
HTTP::respond 403 content “Forbidden” “Content-Type” “text/html”
For POST, I have verified internally and got the postman and see that the key is “_fInArgs=” and it should contain “=#”. I have modified your iRule with these values but still fails.
The Postman body is below. Please let me know if anything else is needed.
@mihaic Thats right Sorry for the confusion, an Internal team was testing this earlier. I got the Postman file from them and checked that the key and value were different.
I already made changes and tested for body with “_fInArgs=” that contains “=#” which did not work tried “_fInArgs=” that contains “SessionFree” which did not work either. your help will be appreciated.
if { [HTTP::method] equals “POST” }{
set http_request_body “?[HTTP::payload [HTTP::header value “Content-Length”]]”
if { [URI::decode [URI::query $request_body _fInArgs=]] contains “=#” } {
log local0. “_fInArgs= : $_fInArgs=”
