Proxy Protocol v1 related articles have already been posted on DevCentral, but there is no v2 support iRule code available. A customer wanted to support Proxy Protocol v2, so I wrote an iRule code for supporting v2.
Back-end server must handle Proxy header prior data exchange.
Code :
when CLIENT_ACCEPTED {
# DEBUG On/Off
set DEBUG 0
set v2_proxy_header "0d0a0d0a000d0a515549540a"
# v2 version and command : 0x21 - version 2 & PROXY command
set v2_ver_command "21"
# v2 address family and transport protocol : 0x11 - AF_INET (IPv4) & TCP protocol
set v2_af_tp "11"
# v2 Address Size : 0x000C - 12 bytes for IPv4 + TCP
set v2_address_length "000c"
# Get TCP port - 2 byte hexadecimal format
set src_port [format "%04x" [TCP::client_port]]
set dst_port [format "%04x" [TCP::local_port]]
# Get Src Address and convert to 4 byte hexadecimal format
foreach val [split [IP::client_addr] "."] {
append src_addr [format "%02x" $val]
# Get Dst Address and convert to 4 byte hexadecimal format
foreach val [split [IP::local_addr] "."] {
append dst_addr [format "%02x" $val]
# Build proxy v2 data
set proxy_data [binary format H* "${v2_proxy_header}${v2_ver_command}${v2_af_tp}${v2_address_length}${src_addr}${dst_addr}${src_port}${dst_port}"]
if { $DEBUG } {
binary scan $proxy_data H* proxy_dump
log local0. "[IP::client_addr]:[TCP::client_port]_[IP::local_addr]:[TCP::local_port] - proxy_data dump : $proxy_dump"
when SERVER_CONNECTED {
TCP::respond $proxy_data
I added IPv6 support like this. I can see room for a bit of improvement, but it works well.
# DEBUG On/Off
set DEBUG 1
# v2 proxy header
# v2 version and command: 0x21 (version 2 & PROXY command)
# Get ports
# Detect IP version
if { [IP::version] == 4 } {
# IPv4
set v2_af_tp "11"
# Convert IPv4 addresses to hex
set src_addr ""
set dst_addr ""
} elseif { [IP::version] == 6 } {
# IPv6
set v2_af_tp "21"
set v2_address_length "0024"
# Convert IPv6 addresses to 16-byte hex
set src_addr ""
set exp_src_addr [split [IP::client_addr] ":"]
foreach block $exp_src_addr {
# If block is null, then v6 address is compressed with ::
if {$block ne ""} {
append src_addr [format "%04x" [scan $block %x]]
# Insert 0000 for each block compressed out of the address
for {set x [llength $exp_src_addr]} { $x <= 8 } { incr x } {
append src_addr "0000"
set dst_addr ""
set exp_dst_addr [split [IP::local_addr] ":"]
foreach block $exp_dst_addr {
if {$block ne ""} {
append dst_addr [format "%04x" [scan $block %x]]
for {set x [llength $exp_dst_addr]} { $x <= 8 } { incr x } {
append dst_addr "0000"
set v2_af_tp ""
set v2_address_length ""
set src_addr ""
set dst_addr ""
if { $DEBUG } {
