Problem with Failover link
Hi!!, I need yours help, i try to linkup the failover interface, but when i add a peer option, this error occurs:
java.io.IOException: Could not read response from server: ParseError at [row,col]:[1,236] Message: The processing instruction target matching “[xX][mM][lL]” is not allowed.
What is the reason of this?
And additional information, we don’t have a hardware link (No lights, green or amber) on failover interface.
I hope you can help me… =(
I found this as a known issue : ID 420213 “You may encounter this error message when attempting to establish trust: 'java.io.IOException: Could not read response from server: ParseError at [row,col]:[1,236] Message: The processing instruction target matching “”[xX][mM][lL]”" is not allowed.’ This indicates that the device that you are attempting to add is not accessible from the current device (there is no route)." Workaround: None
and no solution?, I have to put this on production today, please i need help :confused:
Are both devices’ management addresses in the same management subnet? Are self-IP addresses on each device in the same subnet? Based on ID 420213, it sounds like they simply can’t reach each other over the network
MMMM maybe that is the problem, i going to check and back in a minutes :frowning:
