Hello,
I think I’ll need advices or at least some opinions, here… On the cluster of F5 we manage, the secondary node passed master, one month ago. Besides, I see, in the GUI, the button “force failover” is greyzed. So Impossible to make a failover from that. But.. Maybe I could force it in CLI… I am not yet sure. I didn’t try that, for now (it is not our cluster, so… I must be careful). Anyway… when I have made tests on the clusters, I found that :
show cm failover-status
Status STANDBY (…)
adress IP1:1026 nodename_Sec 0 1 - Error
adress IP21026 nodename_Sec 0 1 - Error
adress IP3:1026 nodename_Sec 30334301 3 2024-Sep-09 16:48:55 Ok
(PS. I do not indicate the real address / node name, of course, here…)
# show /cm traffic-group (…)
traffic-group-1 nodename_Pri standby true false -
traffic-group-1 nodename_Sec active false false peer-offline
# show /sys failover
Failover active for 35d 04:03:10
Well, there is 3 address used for the configSync. The 2 first one are self IPs. They are configured with a port lockdown “none”. Normally, it is not correct, that is ok, I know it. It should be configured on “default” or “allow all”. BUT the management IP work well, obviously. We have a status “ok” for this one. So… Basically, I should be able to make a "failover, in that case, In first view. Except no. Because the button “force failover” is grey.
However, I see too the “peer offline” with my cmd “show /cm traffic-group”.
That means I should be in that situation : https://my.f5.com/s/article/K000137178.
But… the “network -pan” doesn’t show me any “sod off”. So, I am not sure of that, after all.
So,
1/ Do you know if the fact I see the “peer-offline” explain, itself, why my button “force failover” is grey ?
2/ The fact we have only the management IP usable for the configSync is functionnal, according to you ? Could it explain too all the problem ?
3/ I do not see “sod off” with a “netstat -pan” (Cf. the Kb I shared her above). In despite of that, do you think I should restart the sod ?
Brief, is someone knew a similar situation and would have an opinion or a suggestion about it, please ?
Have a nice day end!
Best regards,
Christian
