I receive the same error when processing the command through the TMUI as well. Self IPs in question are both configured as /30 (192.168.3.1 and 192.168.3.2), and 192.168.3.1 is locked to allow udp:1026 only where 192.168.3.2 also temporarily has tcp:443 allowed in addition as this is required for this step. I have tried setting both Self IPs to Allow Default to see if that was the issue, and it is not. I have also attempted to use an incorrect password, and receive a ‘std exception: (iControl authorization failed), exiting…’ error, so I know it is not an authentication issue.
I have been working a SR with the support folks, and we have uncovered the following.
I locked down iControl SOAP access to my environment using the steps listed in K17459. Unfortunately, there appears to be a bug where this particular configuration object doesn’t recognize CIDR notations.
As an example, I attempted both 192.168.1.0/24 and 192.168.1.0/255.255.255.0 to no avail. If I specify the exact IPs of the two DSC Members as individual IPs, the access is permitted.
The NSE and ENE are working toward writing a bug for this. I will update this thread once they have one assigned.
For those seeing this issue, use the workaround above (Specify individual IPs instead of CIDR) and you’ll be able to continue with your work!
Besides the iControl SOAP allowed addresses you also need to ensure that the HTTPD allow list is not restricting communication. Was having the same issue. My iControl SOAP was allowing { All }, but it would still fail with the same error message “getDeviceInfo failed: [xmlHelpers.cpp:90 getXPathValue] expected 1 node for //faultstring, got 0”.
Ensure you’re allowing the IP address of the peer in your HTTPD allow list, which locks down access to the configuration utility. Issue the “list /sys httpd allow” command and if it’s not allowing { All }, then modify it to include the IP address of the peer device by using “modify /sys httpd allow add { x.x.x.x/y }” where x.x.x.x/y is the IP or network address of the peer device. More information on using httpd allow in K13309.
