problem on https and http on vs
Hi
i have a VS with allot of custom things on it SSL offloading on the F5 this i ned to figure our how i’m gonna get this to work on http and https. client side everything is https and server side everything is http. this is the VS
destination 10.211.184.100:20175
ip-protocol tcp
mask 255.255.255.255
partition SOA
pool pool_ttl_dev
profiles {
/Common/tcp { }
/Common/wilcard_mtn {
context clientside
SOA_Profile { }
SOA_expression { }
rules {
Logging
Irule_ttl_dev_http
Streaming_SOA
snat automap
vlans-disabled
this is my http profile.
ltm profile http SOA_Profile {
app-service none
basic-auth-realm none
defaults-from /Common/http
encrypt-cookies none
fallback-host none
fallback-status-codes none
header-erase none
header-insert none
insert-xforwarded-for disabled
lws-separator none
lws-width 80
max-header-count 64
max-header-size 32768
max-requests 0
oneconnect-transformations enabled
pipelining enabled
redirect-rewrite all
request-chunking preserve
response-chunking selective
response-headers-permitted none
security disabled
via-request preserve
via-response preserve
and this the rule that i have…
when CLIENT_ACCEPTED {
switch [TCP::local_port] {
80 {
SSL::disable clientside
SSL::disable serverside
pool pool_ttl_dev
so, what is the problem?
by the way, TCP::local_port won’t return 80 since the virtual is listening on port 20175 i.e. it will return 20175 only.
the problem is that i need this to work like this. if you put in the URI http://www.ttl.com:20175 and https://www.ttl.com:20175 they both should work but thus far i can only get the https to work…
e.g.
[root@ve10:Active] config  b virtual bar list
virtual bar {
   translate service enable
   snat automap
   pool foo
   destination 172.28.19.79:any
   ip protocol 6
   rules myrule
   profiles {
      clientssl {
         clientside
      tcp {}
[root@ve10:Active] config  b pool foo list
pool foo {
   members 200.200.200.101:80 {}
[root@ve10:Active] config  b rule myrule list
rule myrule {
      80 { SSL::disable clientside }
      443 { }
      default { reject }
[root@ve10:Active] config  curl -I http://172.28.19.79
HTTP/1.1 200 OK
Date: Fri, 24 Aug 2012 05:22:17 GMT
Server: Apache/2.2.3 (CentOS)
Last-Modified: Fri, 11 Nov 2011 14:48:14 GMT
ETag: "4183e4-3e-9c564780"
Accept-Ranges: bytes
Content-Length: 62
Content-Type: text/html; charset=UTF-8
[root@ve10:Active] config  curl -Ik https://172.28.19.79
HTTP/1.1 200 OK
Date: Fri, 24 Aug 2012 05:22:22 GMT
Content-Length: 62
I have another problem i have multiple backend application running so i can’t open any on the VS. this is for a SOA implementation thus i have the different VS on different port to segregate the application 20175 is for SOA 20177 BAM and so forth.
sorry i misread the question. what about this one?
virtual bar {
   snat automap
   pool foo
   destination 172.28.19.79:20175
   ip protocol 6
   profiles {
      myclientssl {
         clientside
      tcp {}
pool foo {
[root@ve10:Active] config  b profile myclientssl list
profile clientssl myclientssl {
   defaults from clientssl
   nonssl enable
[root@ve10:Active] config  curl -I http://172.28.19.79:20175
HTTP/1.1 200 OK
Date: Fri, 24 Aug 2012 05:42:17 GMT
Content-Length: 62
[root@ve10:Active] config  curl -Ik https://172.28.19.79:20175
HTTP/1.1 200 OK
Date: Fri, 24 Aug 2012 05:42:24 GMT
Content-Length: 62
thanks Nitass its working
