is it possible to send pool availability logs via HSL? Those logs automatically appear within LTM logs, we would need to send those via High speed logging.
Thanks,
Zdenek
Thanks,
Zdenek
Hello Zdenda.
Yes, of course you can.
Taking into account your log messages are something like this:
Tue Dec 17 21:02:46 CET 2019 notice bigip mcpd[5785] 01070727 Pool /Common/P-WEB1_80 member /Common/N-WEB1_172.16.100.1:80 monitor status up. [ /Common/inband: up ] [ was up for 492hrs:18mins:57sec ]
Tue Dec 17 21:03:46 CET 2019 notice bigip mcpd[5785] 01070727 Pool /Common/P-WEB1_80 member /Common/N-WEB1_172.16.100.1:80 monitor status up. [ /Common/https_443: up ] [ was up for 492hrs:19mins:57sec ]
Tue Dec 17 21:04:19 CET 2019 notice bipip mcpd[5785] 01070638 Pool /Common/P-WEB1_80 member /Common/N-WEB1_172.16.100.1:80 monitor status down. [ /Common/https: down; last error: ] [ was up for 492hrs:20mins:30sec ]
Tue Dec 17 21:04:31 CET 2019 notice bigip mcpd[5785] 01070727 Pool /Common/P-WEB1_80 member /Common/N-WEB1_172.16.100.1:80 monitor status up. [ /Common/gateway_icmp: up ] [ was down for 0hr:0min:12sec ]
You should follow these steps:
1. Configure a Log Destination { > System > Logs > Configuration > Log Destinations }
2. Configure a Log Publisher { > System > Logs > Configuration > Log Publishers }
3. Configure a Log Filter { > System > Logs > Configuration > Log Filters }
This is just an example. You can create your own custom set of message ID using this table.
REF - Log Messages Reference | BIG-IP Documentation
KR,
Dario.
An official reference:
REF - myF5
Hi, that is really helpful. I didn’t realize I could use log filter for this. Thanks for pointing this out, I will try it.
