Hello all,
I am currently working on installing four DCD’s to the F5 estate I manage and am looking to export the logs from the BIG-IP’s to the four DCD’s using an HSL setup to load balance these between these.
Reading through the following link Create a remote logging pool of DCDs (and others) it is clear that different modules require different port numbers to be used for logging but is there a specific port to be used for sending logs from the LTM and GTM modules? I see no reason why this wouldn’t be possible but I can’t find details anywhere that specify which port should be used for these.
Any pointers would be much appreciated.
