How can I disable the nonce in the OSCP request?
In the openssl, I can use the “-no_nonce” command-line switch.
Thanks, Matbel
Thanks, Matbel
Did you try un-checking the “nonce” checkbox under Advanced?
Yes, I tried, but it did not help.
