setup F5vpn using key stored in TPM?
Can I setup an F5VPN connection using a key generated and stored inside the TPM of my Linux laptop? Platform is Debian 13? AFAICT f5fpc is based upon openssl (which could imply PKCS#11 support), but the documentation doesn’t mention it.
The openconnect F5 implementation is not an option, unfortunately, due to company policy.
Hello @adibablu ,
Noticed that you hadn’t gotten any response in a while and wanted to check if you had gotten an answer outside of DevCentral that would allow you to provide an update.
