Below is the pseudo logic requirement
If {Valid Cert exist && IP Range in Internal} Then Route to WebServer (Reverse Proxy) Pool-1 + Set HTTP_HOST Header. If {User accessed x DNS} Then set HTTP_HOST value as x DNS. else If {User accessed y DNS} Then set HTTP_HOST value as y DNS. end If else If {Valid Cert exist && IP Range not in Internal} Then Route to WebServer (Reverse Proxy) Pool-2 + Set HTTP_HOST Header. If {User accessed x DNS} Then set HTTP_HOST value as x DNS. else If {User accessed y DNS} Then set HTTP_HOST value as y DNS. end If else If {No Valid Cert exist && IP Range not in Internal} Then Route to WebServer (Reverse Proxy) Pool-3 + Set HTTP_HOST Header. If {User accessed x DNS} Then set HTTP_HOST value as x DNS. else If {User accessed y DNS} Then set HTTP_HOST value as y DNS. end If
end If
We have an existing application from which i can see how to validate cert and internal ip range but not sure but not sure of writing a proper irule for the above requirement. when CLIENT_ACCEPTED { set ::sslstatuscode 100 set fromBA 0 set gotcert 0 }
when CLIENTSSL_CLIENTCERT { set ::sslstatuscode 100 if {[SSL::cert count] > 0}{ set ::sslstatuscode [SSL::verify_result] log local0. “verify result 1 is [SSL::verify_result]” } }
when HTTP_REQUEST { SSL::session invalidate SSL::authenticate always SSL::authenticate depth 9 SSL::cert mode request SSL::renegotiate enable SSL::renegotiate
log local0. "Renegociating Client Cert, got [SSL::cert count] certs"
if {[SSL::cert count] > 0} {
log local0. "verify result 2 is [SSL::verify_result]"
set gotcert 1
set gotcert 0
if { !([HTTP::uri] equals "/pwd") && !([HTTP::uri] equals "/2fa_dna") && !([HTTP::uri] equals "/2fa")}{
if {$gotcert == 1} {
We check if we're coming from one our Web Proxy
if { ([class match [IP::remote_addr] eq WebProxy])} {
set fromBA 1
Or if we're coming from outside
set fromBA 0
log local0. "ssl status is $::sslstatuscode"
if { ($gotcert == 1) && ($fromBA == 1) }{
HTTP::redirect "https://application.com/pwd"
log local0. "going to pwd"
} elseif { ($gotcert == 1) && ($fromBA == 0) }{
HTTP::redirect "https://application.com/2fa_dna"
log local0. "going to 2fa_dna"
} elseif { ($gotcert == 0) && ($fromBA == 1) }{
HTTP::redirect "https://application.com/2fa"
log local0. "going to 2fa"
log local0. "going to else 2fa"
