Help with iRule
Good day all!
I have the following iRule:
  if { ([HTTP::host] eq "lists.example.com") and ([HTTP::uri] eq "/cgi-bin/wa?INDEX" || [HTTP::uri] eq "/cgi-bin/wa?MOD" || [HTTP::uri] eq "/cgi-bin/wa?SYSCFG" || [HTTP::uri] eq "/cgi-bin/wa?OWNER" || [HTTP::uri] eq "/cgi-bin/wa?INDEX=" || [HTTP::uri] eq "/cgi-bin/wa?LOGON" || [HTTP::uri] eq "/cgi-bin/wa?LOGON=INDEX" || [HTTP::uri] eq "/cgi-bin/wa?LOGON=" || [HTTP::uri] eq "/cgi-bin/wa?ADMINDASH" || [HTTP::uri] eq "/cgi-bin/wa?LSTCR1") } {
              switch -glob [class match [IP::client_addr] eq "LISTSERV-TST_Allowed_IPs"] {
                "1" {
                          return
                default {
                          HTTP::redirect "https://www.google.com/"
  else {
      return
As you can see, it is inefficient, and it doesn’t account for all possibilities. Let me explain what I am aiming.
If an `HTTP_REQUEST` comes to “lists.example.com” (`[HTTP::host]`), and the URI (`[HTTP::uri]`) isn’t “/cgi-bin/wa?SUBEDIT1*” (that is, “cgi-bin/wa?SUBEDIT1”, and anything after it), redirect it unless it is from an IP on the “LISTSERV-TST_Allowed_IPs”, in which case, allow anything on the URI and continue to it.
What would you do?
Hi @Fastidious , untested, but I think this is close to what you’re looking for:
when HTTP_REQUEST priority 500 {
    if { ([HTTP::host] eq "lists.example.com") && ([HTTP::uri] matches_glob "/cgi-bin/wa?SUBEDIT1*") } {
        if { ![class match -- [IP::client_addr] eq "LISTSERV-TST_Allowed_IPs"] } {
            HTTP::redirect "https://www.google.com"
I’m a little fuzzy on your “isn’t” clause for the /cgi-bin requirement, so that might need to be negated or the logic cleaned up a bit.
@JRahm thank you, and very close! I want every client not on “LISTSERV-TST_Allowed_IPs” to be allowed to access line 2, but only line 2. Redirect is there is no match.
Allow access to everything matching “/cgi-bin/wa*” to every client on “LISTSERV-TST_Allowed_IPs” data group.
Would something like this work?
      return
    if { [class match -- [IP::client_addr] eq "LISTSERV-TST_Allowed_IPs"] } {
      return
Or this, rather:
          return
I know we are close, so I am not certain on how to “wrap it up”.  😅
You can negate that second IF as well to avoid the else
    if { (![class match -- [IP::client_addr] eq "LISTSERV-TST_Allowed_IPs"]) &&
         !(([HTTP::host] eq "lists.example.com") && ([HTTP::uri] matches_glob "/cgi-bin/wa?SUBEDIT1*")) } {
Did you miss the ! on `!([HTTP::uri]…`?
@JRahm so, this is “working”:
         (([HTTP::host] eq "lists.example.com") && !([HTTP::uri] matches_glob "/cgi-bin/wa?SUBEDIT1*")) } {
But images are all broken. It is creating a weird CORS/redirect problem
looks like I just put it in the wrong place! Updated above.
might be either a missing use case or the logic is slightly off. If use add the else back in and add return to that block does it fix?
if youre not familiar with programming, use the gui based local traffic policy and/or asks developer team to help
traffic policies are certainly a good option if you don’t already have iRules in place. Personally, if I have any iRules on a virtual, I’ll stick with iRules so I’m not splitting the logic into multiple sources of responsibility. But, if it can all be done in a policy (or multiple policies) that’s the better path.
I had to account for more, and there are other URIs within the page, and those will be blocked because to not match the glob. So:
         (([HTTP::host] eq "lists.example.com") && !([HTTP::uri] matches_glob "/cgi-bin/wa?SUBED1*") && !([HTTP::uri] matches_glob "/archives/images/*")) } {
        return
I know this is out of the scope of my cry for help, but I don’t think I will be able to accomplish what I need with iRules. The page I am trying to “lock” posts to “/cgi-bin/wa” (a form, passing hidden inputs). That “/cgin-bin/wa” does everything. :grimacing:
understood! It still might be possible, but sounds like it will take a deeper dive into the flow and mechanics taking place.
