Issue while saving Irule
Hi all, We have created irule but once we saving the irule it is showing error message as : showing error the requested object name /common/ is invalid
Do we require any special thing while saving irule.
Hi Deepak,
Share the iRule and the actual error you got.
I will try to take snapshot for that , but do we require any license for Irule
No License.
Looks like you’re referencing something that doesn’t exit.
In your iRule can you ensure the Common partition is in the correct case ? ( /Common/
you should correct the object name. for example your object is NAME, but you define it as Name.
Iain , as per my knowledge it does not require license for Irule. But , I had word with F5 and they are telling require GTM License. Temporary we have got trial GTM license for 45 days . Hope if this will work after rebooting device.
