iRules failures counter
Hi Guys,
I am having failures counters increasing on the HTTP_RESPONSE when doing statistics, Local Traffic, iRules.
How do I know what part within the code is the problem at ?.
Thanks, Edouard.
Did you check logs: GUI:
System  ››  Logs : Local Traffic
/var/log/ltm in bash
The irule errors are located within /var/log/ltm or using the webui System >> Logs >> Local Traffic.
You can tighten your search by injecting "
*TCL error*
" in the search field on the Local Traffic logs available in the webui.
When using cli, you can do the following :
zless /var/log/ltm* | grep "TCL error"
You may add additional filters like this :
zless /var/log/ltm* | grep "TCL error" | grep "my_irule_name"
*TCL error*
Excellent thank-you. ! That is what I wanted to know to address my problem. Cheers.
Perfect, and finally what is the tcl error you got ?
