i want to source nat based on the Pool choosen for load balancing
ie :
1-if choosen pool for load balancing is PoolX , source nat using snat-pool-X
2- if if choosen pool for load balancing is PoolY , source nat using snat-object-Y ( thsi SNAt object contains mapping between Origin address & translation address
How are you selecting the pools? In general, you could select a SNAT pool based on the selected pool using a switch statement or datagroup to map pool names to snat pool names:
when LB_SELECTED {
Check the selected pool name
switch [LB::server pool] {
pool1 {
LB pool was pool1, so select the corresponding snat pool
snatpool pool1_snatpool
pool2 {
snatpool pool2_snatpool
default_pool {
LB pool was not pool1 or pool2, so select a default snat pool
snatpool default_snatpool
when LB_SELECTED {
pool1 {
if {[IP::addr [IP::client_addr] equals X.X.X.X]} {
snatpool Y
pool2 {
default_pool {
