iRule for Conditional SNAT
i need to configre iRule for Conditional SNAT while (10.10.10.1 & 10.10.10.2) connecting to the VS SNAT will be 10.214.214.148 and the rest of clients the SNAT will be 10.214.214.147
current setup:
snat pool “DPG-147” = 10.214.214.147 & i have another snat pool “DPG-148” = 10.214.214.148
ltm virtual DPG-Staging-5006
  description Cube
  destination 192.168.30.147:pxc-spvr
  ip-protocol tcp
  mask 255.255.255.255
source 0.0.0.0/0
  source-address-translation
    pool DPG-147
    type snat
Mohanad
Do you really need the SNAT pool, or you just need to definean IP address to SNAT on iRule?
e.g.
# Classic syntax
when CLIENT_ACCEPTED {
    if { [IP::client_addr] eq "10.10.10.1" || [IP::client_addr] eq "10.10.10.2" } {
        snat 10.214.214.148
        snat 10.214.214.147
# Short way
    if { "10.10.10.1, 10.10.10.2" contains [IP::client_addr] } {
        snat 10.214.214.148
        snat 10.214.214.147
# Expansive way, increase list when needed
    switch [IP::client_addr] {
        10.10.10.1 -
        10.10.10.2 {
            snat 10.214.214.148
        default {
            snat 10.214.214.147
You must change line from “snat <IP ADDR>” to “snatpool <POOLNAME>” if you need to use a SNAT pool.
I hope it helps.
Hello.
I would use also one the cjunior irules, but take into account that it’s possible to configure this directly without iRule using 2 virtuals with different source ip. For example.
	description Cube
	ip-protocol tcp
	source 0.0.0.0/0
	pool DPG-147
	type snat
ltm virtual DPG-Staging-5006_2
	description Cube
	ip-protocol tcp
	source 10.10.10.0/30
	pool DPG-148
	type snat
REF - myF5
Also using policies.
REF - Introducing Local Traffic Policies
KR,
Dario.
Thank you cjunior i used pool name for the irule and working successfully
thank you Dario Garrido i prefer using snat instead of creating new VS
