We have pool members that will make http requests to vips with pools the requester could itself be a member of
I need a quick irule to make sure that if a server’s http request cannot be routed back onto itself.
how will you tie the sessions together? Is there something in the original request that would be evident in the request initiated by the server?
if you just want a client can’t be server rule, that shouldn’t be too challenging:
when LB_SELECTED {
if { [IP::client_addr] == [IP::server_addr] }
LB::detach
LB::reselect
You might want to add an escape after X number of attempts to prevent a loop in the event the same member keeps getting selected.
this is mine. i disabled cmp because i wanted to test with one tmm.
configuration
[root@ve11c:Active:In Sync] config tmsh list ltm virtual bar
ltm virtual bar {
cmp-enabled no
destination 200.200.200.10:80
mask 255.255.255.255
pool foo
profiles {
fastL4 { }
rules {
qux
source 0.0.0.0/0
source-address-translation {
type automap
vs-index 9
[root@ve11c:Active:In Sync] config tmsh list ltm pool foo
ltm pool foo {
members {
200.200.200.101:80 {
address 200.200.200.101
200.200.200.102:80 {
address 200.200.200.102
200.200.200.111:80 {
address 200.200.200.111
[root@ve11c:Active:In Sync] config tmsh list ltm rule qux
ltm rule qux {
when CLIENT_ACCEPTED {
log local0. "client: [IP::client_addr]:[TCP::client_port] server:"
when LB_SELECTED {
log local0. "client: [IP::client_addr]:[TCP::client_port] server: [LB::server addr]:[LB::server port]"
if { [IP::client_addr] == [LB::server addr] } {
log local0. "client: [IP::client_addr]:[TCP::client_port] LB::reselect"
LB::reselect
when SERVER_CONNECTED {
/var/log/ltm
[root@ve11c:Active:In Sync] config tail -f /var/log/ltm
Jun 11 19:41:37 ve11c info tmm[10748]: Rule /Common/qux : client: 200.200.200.101:44464 server:
Jun 11 19:41:37 ve11c info tmm[10748]: Rule /Common/qux : client: 200.200.200.101:44464 server: 200.200.200.102:80
Jun 11 19:41:43 ve11c info tmm[10748]: Rule /Common/qux : client: 200.200.200.101:44465 server:
Jun 11 19:41:43 ve11c info tmm[10748]: Rule /Common/qux : client: 200.200.200.101:44465 server: 200.200.200.101:80
Jun 11 19:41:43 ve11c info tmm[10748]: Rule /Common/qux : client: 200.200.200.101:44465 LB::reselect
Jun 11 19:41:43 ve11c info tmm[10748]: Rule /Common/qux : client: 200.200.200.101:44465 server: 200.200.200.111:80
Jun 11 19:41:49 ve11c info tmm[10748]: Rule /Common/qux : client: 200.200.200.101:44466 server:
Jun 11 19:41:49 ve11c info tmm[10748]: Rule /Common/qux : client: 200.200.200.101:44466 server: 200.200.200.102:80
