I’m still learning here, so bear with me. I am trying to write an irule that will catch requests trying to pull content from a specific set of hosts (ex. myserver1.domain.com, myserver2.domain.com, myserver3.domain.com) and return a 200 status code.
Here is what I have put together, but I’m not sure what I have wrong.
if { [HTTP::uri]} contains ‘myserver’ [HTTP::respond 200]
TIA,
DarkSide
You’d want to use HTTP::host rather than HTTP::uri in this case, since myserver is part of the hostname and not the uri. This also assumes that those hostnames all point to the same virtual server address in DNS. Is that what you are looking for?
Also, just responding with a 200 and no content probably won’t yield much, but maybe that’s what you want.
Denny
Denny’s right, so what you’d want instead is something like:
switch -glob [HTTP::host] {
"*myserver1.domain.com" -
"*myserver2.domain.com" -
"*myserver3.domain.com" {
HTTP::respond 200 content "Response from LTM iRule"
Of course you can get a lot more detailed in the response you want to send, too. Take a look at the HTTP::respond wiki page for some examples - Click here
HTH,
Colin
You guys are awesome, thanks a bunch. Course, now I’ve realized I was totally off-base with what I had put together. Is there a good link (maybe the wiki one you provided Colin) that will help me learn the irule syntax that is available in these devices? I know it’s TCL based (which I don’t know and must learn now), but read that not all TCL commands are implemented.
Colin - Yes, they are all pointing to the same vip, which was serving up some sort of content. The app owner is decommissioning the app and wanted the LB to simply return a 200 status to any 3rd parties were still pointing to it.
Thanks Again,
-DarkSide
nm…if i had bothered to look at the “Spotlight Wikis” links, I would have found what I seek.
Again…Thanks!
