iRule not working properly
Hello,
I am using the iRule below but when I enter http://site.name/bd, I don’t get redirected to site.name…
Any help would be greatly appreciated.
Rusty
when HTTP_REQUEST { if {(([HTTP::uri] equals “/”) or ([HTTP::uri] equals “/levi_b2b/init.do”))} { HTTP::uri “/levi_b2b/init.do” } elseif {[HTTP::uri] equals “/bd*”} { HTTP::uri “/bd/public/frameset_top_html.jsp” } else { HTTP::redirect http://leo.levi.com/index.htm } }
im not sure you can actually use wildcards in an equals, so in
{[HTTP::uri] equals "/bd*"}
, what if you try it with contains or starts with?
also it seems to forward you to something else then http://site.name/bd/folder/…, but perhaps your script at /bd/public/frameset_top_html.jsp does that?
e.g.
[root@ve1023:Active] config b virtual bar list
virtual bar {
snat automap
pool foo
destination 172.28.19.79:80
ip protocol 6
rules myrule
profiles {
http {}
tcp {}
[root@ve1023:Active] config b rule myrule list
rule myrule {
if {([HTTP::uri] equals “/”) or ([HTTP::uri] equals “/levi_b2b/init.do”)} {
} elseif {[HTTP::uri] equals “/bd”} {
HTTP::redirect “/bd/public/frameset_top_html.jsp”
HTTP::redirect “http://leo.levi.com/index.htm”
[root@ve1023:Active] config curl -I http://172.28.19.79/bd
HTTP/1.0 302 Found
Server: BigIP
Connection: Keep-Alive
Content-Length: 0
I’ve actually tried that way as well but ti didn’t work. It seems to me that the iRules is being entered multiple times ( I see this using the LOG command ).
Here is some information from the log file. All this occured from just one hit ( the first BD is just an indicator to which If statement I took:
bd - uri = /bd
bd - uri = /bd/
bd - uri = /bd/public/frameset_top_html.jsp
bd - uri = /bd/frameset_application.sap
bd - uri = /bd/navigation_top.sap
bd - uri = /bd/startEBPP.sap
bd - uri = /bd/navigation.sap
Here is my latest effort as writing this iRule:
switch [string tolower [HTTP::uri]] {
“/” { HTTP::uri “/levi_b2b/init.do”}
“/levi_b2b” { HTTP::uri “/levi_b2b/init.do”}
“/docs” { HTTP::uri “/docs/index.html”}
“/bd” { HTTP::uri “/bd/public/frameset_top_html.jsp”}
default { HTTP::redirect “http://leo.levi.com/index.htm” }
can you try to remove the default case?
e.g.
"/" { HTTP::uri "/levi_b2b/init.do"}
"/levi_b2b" { HTTP::uri "/levi_b2b/init.do"}
"/docs" { HTTP::uri "/docs/index.html"}
"/bd" { HTTP::uri "/bd/public/frameset_top_html.jsp"}
It works. Why is that?
But I still need the switch to take the default so how do I make this happen if it makes the iRule not work?
Hi Rusty Tripp,
You can use Wildcards inside of a switch statement to make things fit and act properly as well as set a default action if none of the conditions are met.
I took your original iRule and converted. The “-” at the end of each qualifier tells the iRule that if it qualifies follow the same action as the NEXT item on the list, so in this example all of them will set the HTTP::uri value. If none of them qualify then you will be redirected.
switch -glob [string tolower [HTTP::uri]] {
"/levi_b2b/init.do" -
"/bd*" { HTTP::uri "/bd/public/frameset_top_html.jsp" }
default { HTTP::redirect http://leo.levi.com/index.htm }
Hope this helps.
