Hi, i have a simple redirection irule which is not working . Here it is
when HTTP_REQUEST { if { [HTTP::host] equals “cmsint-qa.abc.com/public/header.html?SiteId=GCR ”} { HTTP::redirect “https://gcr-qa.abc.com/public/header.html\[HTTP::uri] ” } }
The redirected website opens just fine and DNS looks ok. Any ideas what i am doing wrong here?
JRahm
January 8, 2014, 12:07am
2
HTTP::host is only the host, it doesn’t include the URI.
host: cmsint-qa.abc.com path: /public/header.html uri: /public/header.html?SiteId=GCR
you’ll want to split the conditions up so they’ll match. You can add the host condition in there as well, but without it, something like this should work:
if { [HTTP::uri] equals "/public/header.html?SiteId=GCR"} {
HTTP::redirect "https://gcr-qa.abc.com/public/header.html[HTTP::uri]"
nitass
January 8, 2014, 2:00am
3
e.g.
config
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar
ltm virtual bar {
destination 172.28.20.15:80
ip-protocol tcp
mask 255.255.255.255
pool foo
profiles {
http { }
tcp { }
rules {
myrule
source 0.0.0.0/0
source-address-translation {
type automap
vs-index 34
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule myrule
ltm rule myrule {
if { [HTTP::host] equals "cmsint-qa.abc.com" and [HTTP::uri] equals "/public/header.html?SiteId=GCR" } {
HTTP::redirect "https://gcr-qa.abc.com[HTTP::uri]"
test
[root@ve11a:Active:In Sync] config curl -I http://172.28.20.15/public/header.html?SiteId=GCR -H "Host: cmsint-qa.abc.com"
HTTP/1.0 302 Found
Location: https://gcr-qa.abc.com/public/header.html?SiteId=GCR
Server: BigIP
Connection: Keep-Alive
Content-Length: 0
Yes, that works. Thanks nitass
