IP Conflict?!
Hi Guys,
I just looked in the F5 log and I saw this error:
Aug 24 07:13:29 local/tmm warning tmm[6300]: 01190004:4: address conflict detected for {ip address} (00:1b:21:15:b1:44) on vlan 4091
and there is no such IP address anymore except on the F5 (which own this ip address)
Any suggestions?
If you’re using 9.3.x and active-active configuration, SOL8830 might be related:
1st of all I want to thank you for your help but I got only 1 machine and the version is 10.x.x
Any other idea?or what can I do?
You said, “there is no such IP address ANYMORE except on the F5.” Did that IP address used to exist on another device? If so, it is possible that the F5 still has an ARP entry for that “old” MAC address. Also, is there a firewall on that same VLAN somewhere. If so, the firewall may be Proxy ARP’ing for that address if it is configured for a NAT translation for that address or address space.
Joe
Yes, the IP was mistakenly been used by other device, which is not exist anymore, how can I delete the ARP entry of the old MAC address in the F5?
The IP is not configured at all in the firewall security and the in the address translation services.
Posted By Ido Katz on 08/24/2010 07:38 AM
Through GUI: Network → Arp → Dynamic List
Try “bigpipe arp 10.10.10.20 delete” from the command line. Obviously replacing that IP address with the one in question.
How can I be sute that i’m deleting the right arp entry of the old server and not the arp entry of the F5 himself?
Posted By Ido Katz on 08/24/2010 07:55 AM
The F5 shouldn’t have a dynamic entry for himself.
I couldn’t find the address in the dynamic ARP entry for the IP address, any other suggestions?
Posted By Ido Katz on 08/24/2010 08:47 AM
From the command line: arp -a | grep ‘1.1.1.1’ Replace the ip with the one about which you’re concerned.’
I did the arp -a but I got no match found, what does grep do?
Posted By Ido Katz on 08/24/2010 08:56 AM
If arp -a outputs multiple lines, piping it to grep allows you to output only the matching lines. If the issue isn’t still logging, I’d probably ignore it…doesn’t seem like the F5 knows about it…
How much time does the grep takes? I did it 3 minutes ago but he is still in progress
Wow. How big is that subnet? 10.0.0.0/8 or what? Seriously though, if you haven’t seen the error log recently it has probably aged out of the arp cache and you don’t need to worry about it.
and if I need to ignore it, how can I make this error go away?
Posted By Ido Katz on 08/24/2010 09:14 AM
I wouldn’t ignore it unless it doesn’t happen again. If it continues to show up, you should look into.
trace that mac in your layer2 infrastructure and find out what port it is being learned on. That will lead you to the offending party.
Not sure if this can help someone - have just seen something similar. For us the address conflict seen on an LB HA pair was caused by a disabled virtual server on another standalone load balancer on the same VLAN. After deleting the disabled VS from the other LB, the log entries no longer appear.
tmm[5861]01190004address conflict detected for xxx.xxx.xxx.xxx (xx:xx:xx:xx:xx:xx) on vlan XXX
remember you can to delete the virtual address.
Local traffic >> virtual servers >> virtual address list
