I did see an interesting issue with DNS Express with Next for Kubernetes when playing in a test environment. When you have 2 TMM pods in the same namespace as the DNS zone mirroring is done by zxfrd pod and I you need to create a listener “F5BigDnsApp” as shown in CNF DNS Express for the optional notify that will feed this to the TMM and then to the zxfrd pod.
The issue happens when you have 2 or more TMM as then the “F5BigDnsApp” that is like virtual server/listener as then then on the internal vlans there is arp conflict as the two tmm on two different kubernetes/openshift nodes advertise the same ip address on layer 2. This is seen with “kubectl logs” (“oc logs” for Openshift) on the TMM pods that mention the duplicate arp detected. Interesting that the same does not happen when you do this for the normal listener on the external Vlan (the one that captures and responds to the client DNS queries) as I think by default the ARP is stopped for the external listener that can be on 2 or more TMM as ECMP BGP is used to redistribute the traffic to the TMM by design.
I see 4 possible solutions as I see it. One is to be able to control the ARP for the “F5BigDnsApp” CRD for Internal or External Vlans (BGP ECMP to be used also on the server side then) and the second is to be able to select “F5BigDnsApp” to be deployed just one 1 TMM even if there are more. Also if an ip address could be configured for the listener that is not part of the internal ip address range but then as I see with “kubectl logs” on the ingress controller (f5ing-tmm-pod-manager) the config is not pushed to the TMM as also with “configview” from the debug sidecar container on the tmm pods there is no listener at all. The manager logs suggest that because the Listener IP address is not part of the Self-IP IP range under the intnernal Vlan as this maybe system limitation and no one thinking about this use case as in BIG-IP this is is supported to have VIP on non self ip address range that is not advertised with arp because of this.
The last solution that can work at the moment is to have many tmm in different namespaces on different kubernetes nodes with affinity rules that can deploy each tmm on different node even if the tmm are on different namespaces by matching a configured label (see the example below) as maybe this is the current working design to have one zxfrd pod with one tmm pod in a namespace but then the auto-scaling may not work as euto scale should create a new tmm pod in the same namespace if needed.
Example:
affinity:
podAntiAffinity:
requiredDuringSchedulingIgnoredDuringExecution:
- labelSelector:
matchLabels:
app: tmm
# Match Pods in any namespaces that have this label
namespaceSelector: {} # empty selector = all namespaces
topologyKey: “kubernetes.io/hostname”
Also it should be considered if the zxfrd pod can push the DNS zone to the RAM of more than one TMM pods as maybe it can’t as maybe currently only one to one is supported. Maybe it was never tested what happens when you have Security Context IP address on the Internal Network and multiple TMM pods.
Interest stuff that I just wanted to share as this was just testing things out![]()
