Hi All,
We have two customers which are trying to install 14.1.2.6 on a partition prior to upgrade from 14.1.2.5. But the installation fails right away with the following erros in /var/log/liveinstall.log
*** Live install start at 2020/07/06 18:08:23 ***
info: tm_install::BootLoader::BootLoader_mboot_sync_from_old_conf -- Configurations match.
info: Daemon-driven execution indicated by ENV variable.
info: Repository tm_install version/release is 2.12.0.6/4.0
info: System tm_install version/release is 2.12.0.6/4.0
info: Platform id is C117
/dev/sdd: No medium found
sfdisk: cannot open /dev/sdd for reading
info: Basic disk format validation passed.
info: >++++ result:
info: mount: /dev/mapper/vg--db--sda-set.2._usr is already mounted or /mnt/tm_install/30655.GyI1Fy/usr busy
info: /dev/mapper/vg--db--sda-set.2._usr is already mounted on /usr
info: /dev/mapper/vg--db--sda-set.2._usr is already mounted on /opt/.sdm/usr
info: /dev/mapper/vg--db--sda-set.2._usr is already mounted on /opt/.sdm/lib
info: /dev/mapper/vg--db--sda-set.2._usr is already mounted on /opt/.sdm/lib64
info: >----
error: status 8192 returned by command: mount -oro /dev/vg-db-sda/set.2._usr /mnt/tm_install/30655.GyI1Fy/usr 2>/dev/null
info: >++++ result:
info: umount: /mnt/tm_install/30655.GyI1Fy/shared: not mounted
info: >----
error: status 8192 returned by command: umount /mnt/tm_install/30655.GyI1Fy/shared
Terminal error: Could not access configuration source; sda, 2
*** Live install end at 2020/07/06 18:08:27: failed (return code 2) ***
I could not find anything related in the F5 knowledge base articles.
Customer already tried to delete an create a partition again, but this did not solve the issue.
Anyone else facing the same issue? Anyone has a solution?
Regards,
Martijn
