Unable to install firmware OS and drop at 10%
info: >++++ result:
info: >----
info: tm_install::RPM::rpm_db_find_by_namearch -- not found : MySQL-shared/i686
error: tm_install::Product::get_package_db -- package MySQL-shared (i686) has been lost.
error: db-based package set requested; no db exists.
error: couldn’t get package list file for LTM.ROS.SAM.SUM.TS.WA.WOC group
Terminal error: Failed to install.
*** Live install end at <timestamp-removed> failed (return code 255) ***
Please let me know when you faced this issue or root cause.
Hi Kamike,
Could you please check free disk space should be available around 15GB for upgrade version, please find reference official f5 link below,
Ensuring the BIG-IP system has sufficient volume disk space available for a software upgrade
Did you get further on this @KaMike ?
If you have a support contract then a F5 support ticket is often a quicker way to go.
