http to https
Hi i create a policy that redirects http to https however when i refresh the page it displays Unable to connect what is the problem? i created HTTPS pool and Http VS
What do you mean by created a policy for the redirect? Did you create the redirect with the default iRule configured on a HTTP virtual server?
I would check if you configured a client SSL profile and server SSL profile to the HTTPS virtual server. Also look at SNAT if applicable.
Regards, Martijn.
