HTTP responser header insert base on URI
Hi all,
how can we insert HTTP RESPONSE header base on URI? Example, if HTTP request URI contains “/test/header/”, I need to insert a new header “Via test_server” in the HTTP RESPONSE header.
Can iRule do this?
thank in advance.
Hi kky,
Sure, here is an example:
     Check if some condition in the request is true
    if {[HTTP::path] starts_with "/test/string"}{
        Track that we want to insert a header in the response
       set insert_response_header 1
        Track that we do not want to insert a header in the response
       set insert_response_header 0
 when HTTP_RESPONSE {
     Check if we're inserting a header in the response
    if {$insert_response_header}{
        Insert the header
       HTTP::header insert "my_header_name" "my_header_value"
Aaron
hi Aaron,
thank for your help.
it work great…
