An application from the company I work for is receiving CORS failure because they did not implement the “Access-Control-Allow-Origin” header in the application.
I want to insert this header via iRule. Something like:
If the Access-Control-Allow-Origin header does not exist
then
insert Access-Control-Allow-Origin header “*.xyz.com”
Hi! The pseudocode looks pretty good, so just need to fill in the specifics. This is an example we use for some other security-related headers:
when HTTP_RESPONSE priority 500 {
if { !([HTTP::header exists "Access-Control-Allow-Origin"]) } {
HTTP::header insert "Access-Control-Allow-Origin" "*.xyz.com"
The body of the if block will only execute if the statement in the first set of curly braces evaluates to true.
Anything in square brackets will be evaluated and replaced with the returned value. [HTTP::header exists “Access-Control-Allow-Origin”] will evaluate to true if the header exists, and false if it is missing. Because the if statement is required to be true for the code to execute, we need to reverse the condition. !(…) will do this.
A missing header evaluates to !([false]) == true, and the header will be inserted. If the header is found, it will evaluate to !([true]) == false, and the header will not be inserted.
