HTTP_REQUEST not firing
I have created the following silly rule.
  log local0. "This is the host uri: [HTTP::uri]"
  node 10.20.252.64
All I want is that on every request log the uri and then bypass the LB and forward the request to a node.
After requesting the VS the log is not updated with my entry, nor the request is redirected to the node.
Is this something achievable. I was following this sample.
Any help would be greatly appreciated.
Try adding port to your node and see if that works.
log local0. “This is the host uri: [HTTP::uri]”
node 10.20.252.64 XXXX -->port number
The Issue was that I must have at least one member of the pool associated with the Virtual Server enable. That is not the case when I use CLIENT_ACCEPTED event type where the even will trigger regardless if I have all the pool members disabled or not.
That is quite easy to explain. If you have no pool members then HTTP_REQUEST never fires. CLIENT_ACCEPTED fires independent from VS being able to process any HTTP traffic.
Piotr
