HTTP/1.1 response from F5 for HTTPS VIP
Dear All,
We have a F5 with version IP 10.0.1 Build 378.0 Hotfix HF3.
I need HTTP/1.1 response from the F5 with 502 code for a HTTPS VIP.
We have tried the below iRule using SSL::respond:
when LB_FAILED { SSL::respond “HTTP/1.1 502 Bad Gateway\r\nServer: BigIP\r\nConnection: close\r\nContent-Length: 0\r\n\r\n” }
However the desired output was not obtained.
As per the previous updates above I see that this should work in version 10 as per below discussion:
http://devcentral.f5.com/Forums/tabid/1082223/asg/50/showtab/groupforums/afv/topic/aff/5/aft/60438/Default.aspx
Can anyone update if there is any issue with the iRule we tested.
Thanks,
Praveen
Do you have a client SSL profile added to the virtual server? If so, you can use HTTP::respond instead of SSL::respond. The syntax should be about the same. Also, make sure to use \r\n as this is the delineator for HTTP headers.
Aaron
We have used the attached iRule wherein we have used HTTP::respond and it did not work.
Anything wrong with the iRule above?
Hi Praveen,
Sorry, I’ve been missing the point in your posts on this. You need to send an HTTP 1.1 response, but HTTP::respond doesn’t currently support sending an HTTP 1.1 response. There is a request for enhancement ID, 337768, which tracks the request to send an HTTP response with a version that matches the original request version. There’s a suggestion to add a flag to override this behavior if you want to hard code the response version.
I’m not sure why SSL::respond isn’t working in LB_FAILED. I suggest opening a case with F5 Support on this. I found one case related to this issue (which might be from your reseller?) but the specific issue of SSL::respond not working in LB_FAILED wasn’t investigated fully.
Hope this helps,
Aaron
