Systeminformation:
F5 BIG-IP r2600
Version 17.1.1.1 Build 0.0.2
Hello everyone,
We would like to map the following scenario with the f5 BIG-IP
I call https://server.domain.com port 443. The BIG-IP should then forward to http://server.domain.com port 55000.
Is this even possible? How did you solve it?
Configuration:
For port translation, we entered port 443 in the virtual server and gave the pool member port 55000.
For HTTPS to HTTP we used the following iRule:
# Extrahiere den Host und den URI aus der HTTPS-Anfrage
set host [HTTP::host]
set uri [HTTP::uri]
# Leite die Anfrage an die HTTP-Version der gleichen URL weiter
HTTP::respond 301 Location “http://$host$uri”
log “iRule_HTTP, HTTPS-Anfrage wurde auf HTTP umgeleitet: $host$uri, ClientIP: [IP::client_addr], ClientPort: [TCP::client_port]”
Is the iRule log entry generated before the port translation? The wrong port is in the logs.
Best regards
