I am trying to send logs to a remote server via port 514, here is what I put into my irule:
when CLIENT_ACCEPTED { set hsl [HSL::open -proto UDP -pool syslog-server-pool]
} when SERVER_CONNECTED { HSL::send $hsl “IP accessing VIP is: [IP::client_addr]:[TCP::client_port] -- bigip made connection from [IP::local_addr]:[TCP::local_port serverside] to pool member [IP::server_addr]:[TCP::server_port]” } when i set log local.0 in each of the events, they are generating logs, which means the events are actually taking place. But i dont see any logs in my target server iam using tmm interface through a self-ip to send logs the syslog pool has member monitor setup which is green. my version of bigip is 10.2.4, i dont see any logs for HSL when the events are triggered, they are not seen on the remote server as well. Any help with this is appreciated.
