If I want to see all of the client connections connecting to a pool member from the CLI I can do something like a “show sys connection ss-server-addr 1.2.3.4”. I can also do this using Postman mapping to ";, but I cannot figure out how to do this via Python.
Using Python if I try to connect to “bigip.sys.raw” I do not see a module called “connection” or anything similar. Does anyone know how, or have some sample code on how to accomplish this?
Thanks Jason. I am able to get stats the way you describe, but what I am trying to get is the actual connected clients connected to each pool member. For example from the CLI if I do a
That example was a virtual IP, but was just the example IP I had in front on me. In reality I need this for both virtual servers and pool members.
But in any case, when I use your example for pool members I get the output of the value of the number of connected clients instead of the list of client IP’s connected to the pool member as I showed above. My results for that code give me:
{'value': 5}
What I need is the list of those 5 IP’s that are currently connected to that pool member which I can get using the CLI command “show sys connection ss-server-addr x.x.x.x”
{'value': 5}
