Just trying to generate a CSR for a GoDaddy cert and I am running into a small problem. GoDaddy require CSR keylengths between 2048 and 4096 and it appears that the Firepass is generating a 1024 key length and there doesn’t appear to be an option to specify the CSR key length using the web interface. Is there anyway of specifying the CSR keylength or are we stuck with whatever key length it currently generates?
I hope that through helping others I can learn more about the Firepass myself. I wish this forum was more active so we could have more discussions about all the various FP features.
well I now have a 2048 Godaddy ssl cert now indtalled on the Firepass. Thanks for the pointer to the article. The only issue I had was that the cert must include a pass phrase or else the FP will not allow you install it, well at least not via the web interface, I’m sure it could be installed via the shell.
I am also trying to generate a 2048 bit CSR for enTrust for the Firepass and will appreciate if you can help to answer my question about using the OpenSSL to create the CSR. I am using the command line as the support page.
I have not tested all the 6.0.3 versions, only up to 6.0.3.2.1. It was missing in 6.1 and added back in 6.1.1. So it could be a newer version of 6.0.3 I guess, it is no longer supported though.
