For anyone that is interested, I recently was posed with the problem of proxying ldap requests. The requirement was to send read and write requests to different pools. As any familiar with ldap knows, you need to send a bind request to authenticate. The following will transparently resend the bind requests to the newly selected server prior to sending the new read/write request.
Other functionality could be added to this, such as more verification of the ldap fields to ensure a valid request is being made.
class ldap_writes {
6
8
10
12
rule ldap_proxy {
when RULE_INIT {
Read Pool
set ::readPool sun_ldap_read
Write Pool
set ::writePool sun_ldap_write
Turn on debugging
set ::debug 0
A lookup table for debugging
array set ::msg_types {
0 "bind request"
1 "bind response"
2 "unbind request"
3 "search request"
4 "search response"
6 "modify request"
7 "modify response"
8 "add request"
9 "add response"
10 "delete request"
11 "delete response"
12 "modifydn request"
13 "modifydn response"
14 "compare request"
15 "compare response"
16 "abandon request"
23 "extended request"
24 "extended response"
when CLIENT_ACCEPTED {
set rebind 0
set binding ""
set replayop ""
set writing 0
TCP::collect
when CLIENT_DATA {
Grab the current payload collected
set payload [TCP::payload]
Pull the first 2 bytes.
binary scan $payload H2c ber_t ber_len
The first byte is the tag signifying an LDAP message,
Always is hex 30, if that is not so reject
if { $ber_t ne "30" } {
reject
return
The second byte is one of two values:
a) The length of the packet minus the above
defining byte and the length byte
OR
b) an octet describing how many subsequent bytes
hold the packet length
In either case the message type (what we are after)
follows the message id field which too can be a variable
number of bytes.
set len_bytes 0
if { [expr [expr ($ber_len + 0x100) % 0x100] & 128] > 0 } {
set len_bytes [expr [expr ($ber_len + 0x100) % 0x100] & 127]
How many bytes is the message id
binary scan $payload x[expr 3 + $len_bytes]c msgid_bytes
The message type is then 4 bytes + number length bytes + number of
message id bytes offset.
binary scan $payload x[expr 4 + $len_bytes + $msgid_bytes]c msgtype
msgtype - BER encoded value, bits 1-5 are the actual
type, 6 is the data type, 7-8 are the data class
Here we only care about the lower 5 bits
set msgtype [expr $msgtype & 31]
if {$::debug and
[catch {
log local0. "message type is: $::msg_types($msgtype) $msgtype"
log local. "Bad message type: $msgtype"
reject
Each connection should start with a bind request
We'll save this packet for later rebinding when we
flip between servers
if { $msgtype == 0 } {
if {$::debug} {log local0. "Bind Request with: ldap_read"}
set writing 0
set rebind 0
set binding $payload
LB::detach
pool $::readPool
If we come across a write request and are currently not
sending data to the write pool, detach, and set the rebind
flag so we can send the bind packet before we actually send
our write request
} elseif {[matchclass $msgtype equals $::ldap_writes] and $writing != 1} {
if {$::debug} {log local0. "Rebinding with: ldap_write"}
set rebind 1
set writing 1
set replayop $payload
TCP::payload replace 0 [TCP::payload length] $binding
LB::detach
pool $::writePool
If we come across a read request while we are bound to a write server
we need to detach and rebind with a read server from the read pool
} elseif {![matchclass $msgtype equals $::ldap_writes] and $writing == 1} {
if {$::debug} {log local0. "Rebinding with: ldap_read"}
set rebind 1
set writing 0
LB::detach
pool $::readPool
TCP::release
TCP::collect
when SERVER_CONNECTED {
A change in the type of request has been detected
requiring a rebind, we've sent the bind now we need to
wait for the response before we send the actual request
if { $rebind == 1 } {
TCP::collect
when SERVER_DATA {
set rebind 0
See above for details on this block. Stupid iRules, no proc grrrr
set len_bytes 0
If the msgtype we have here is for a bind response just discard
it as we don't need to send it to the client
if {$msgtype == 1 } {
TCP::payload replace 0 [TCP::payload length] ""
Now send the actual read or write op to the server
It should now have processed the bind
TCP::respond $replayop
TCP::release
I’m currently facing a problem and it looks liike this irule is most of the way toward what I need. I’m facing an application which performs an ldap modify to create an account, followed by a search to verify the account’s existence, and finally another modify to set a password. As this occurs too quickly for our LDAP servers to replicate, we need to persist these connections. Since there’s only a small number of client’s connecting to this VIP, the result is far from ideal load balancing.
In order to correct this, I’m hoping to modify this irule to allow for persistence based on the CN extracted from the search or modify packet. I think I can handle most of this, but I’m not familiar with LDAP at such a low level as to be able to pull the CN from these packets. Can anyone help me out or point me in the right direction? With the above (wonderfully commented by the way) as a guide, I just need a little help in parsing out the CN from a SearchRequest or ModifyRequest.
What did you want it to do? For stats, you may get more info from the ldap_stats_measuring irule… DevCentral however you do need somewhere to send the hsl logs to and calculate the figures (Does response times per user, number of ops etc).
My purpose is exactly what the above iRule does, i.e. send read requests to read pool and write requests to write pool. However, in my test it doesn’t seem to work with LDAPs in version 10.
With version 11, it complains the following:
Apr 18 18:35:55 tmm err tmm[6687]: 01220001:3: TCL error: /Common/LDAP-Proxy-Nehta - can’t read “::ldap_writes”: no such variable while executing “matchclass $msgtype equals $::ldap_writes”
I have defined ldap_writes in data group as integer type.
Apr 18 18:35:55 tmm err tmm[6687]: 01220001:3: TCL error: /Common/LDAP-Proxy-Nehta - can’t read “::ldap_writes”: no such variable while executing “matchclass $msgtype equals $::ldap_writes” in v11, please remove $:: when refering to data group.
we have to use SSL:: instead of TCP:: command since it is SSL.
this is my configuration. anyway, i never tested ldap write.
root@ve1110(Active)(/Common)(tmos) list ltm virtual bar
ltm virtual bar {
destination 172.28.19.252:636
ip-protocol tcp
mask 255.255.255.255
profiles {
myclientssl {
context clientside
serverssl-insecure-compatible {
context serverside
tcp { }
rules {
myrule
snat automap
vlans-disabled
root@ve1110(Active)(/Common)(tmos) list ltm profile client-ssl myclientssl
ltm profile client-ssl myclientssl {
app-service none
cert salmon.crt
defaults-from clientssl
key salmon.key
root@ve1110(Active)(/Common)(tmos) list ltm data-group internal ldap_writes
ltm data-group internal ldap_writes {
records {
6 { }
8 { }
10 { }
12 { }
type integer
root@ve1110(Active)(/Common)(tmos) list ltm pool sun_ldap_read
ltm pool sun_ldap_read {
members {
200.200.200.103:636 {
address 200.200.200.103
root@ve1110(Active)(/Common)(tmos) list ltm pool sun_ldap_write
ltm pool sun_ldap_write {
members {
200.200.200.113:636 {
address 200.200.200.113
root@ve1110(Active)(/Common)(tmos) list ltm rule myrule
ltm rule myrule {
when RULE_INIT {
Read Pool
set static::readPool sun_ldap_read
Write Pool
set static::writePool sun_ldap_write
Turn on debugging
set static::ldap_debug 1
array set static::msg_types {
0 "bind request"
1 "bind response"
2 "unbind request"
3 "search request"
4 "search response"
6 "modify request"
7 "modify response"
8 "add request"
9 "add response"
10 "delete request"
when CLIENTSSL_HANDSHAKE {
set rebind 0
set binding ""
set replayop ""
set writing 0
SSL::collect
when CLIENTSSL_DATA {
set payload [SSL::payload]
reject
return
OR
number of bytes.
set len_bytes 0
if {$static::ldap_debug and
[catch {
log local0. "message type is: $static::msg_types($msgtype) $msgtype"
log local0. "Bad message type: $msgtype"
reject
if {$static::ldap_debug} {log local0. "Bind Request with: ldap_read"}
set writing 0
set rebind 0
LB::detach
pool $static::readPool
our write request
} elseif {[matchclass $msgtype equals ldap_writes] and $writing != 1} {
if {$static::ldap_debug} {log local0. "Rebinding with: ldap_write"}
set rebind 1
set writing 1
SSL::payload replace 0 [SSL::payload length] $binding
LB::detach
pool $static::writePool
} elseif {![matchclass $msgtype equals ldap_writes] and $writing == 1} {
if {$static::ldap_debug} {log local0. "Rebinding with: ldap_read"}
set rebind 1
set writing 0
LB::detach
SSL::release
SSL::collect
SSL::collect
when SERVERSSL_DATA {
set rebind 0
set len_bytes 0
SSL::payload replace 0 [SSL::payload length] ""
SSL::respond $replayop
SSL::release
[root@ve1110:Active] config tail -f /var/log/ltm
Apr 19 02:44:31 tmm info tmm[7321]: Rule /Common/myrule : message type is: bind request 0
Apr 19 02:44:31 tmm info tmm[7321]: Rule /Common/myrule : Bind Request with: ldap_read
Apr 19 02:44:31 tmm info tmm[7321]: Rule /Common/myrule : message type is: search request 3
Apr 19 02:44:31 tmm info tmm[7321]: Rule /Common/myrule : message type is: unbind request 2
If you’re using v10 or above, it might be better to replace all the matchclass’es with their [class .. ] equivalent. The class command is more flexible, and has better performance that the deprecated functions.
