F5 Sending resets
Hi can someone please tell me what causes this, cant find any reference to this:
this is being sent from the F5 to the client/requestor IP and breaking a lot of connections intermittently, its working about 60% of the time and fials the other 40%
RST cause: [29068a1:5584] {peer} SSL proxy shutdown
Length: 27
0000 000. = Version: 0 (0x00)
… …1 = Peer: 1
Value: 0x0000029068a1
Line: 5584
Cause: SSL proxy shutdown
Its just a normal virtual server running on 443 and the backend server is unecrypted on port 80 (not apm)
@JamesCrk Can you please share the associated F5 configuration so we can look at this in a bit more detail. Feel free to redact anything that you would not like for us to see such as device IPs and/or names.
do you use custom cipher list in vs’s client side ssl profile?
