RST after client hello
The HTTPS health check from F5 for the backend server is failing. From the captures, I can see that the backend server is sending RST as soon as it receives SSL client hello from F5. When we tried to access the web page from the LAN network using the browser directly to the backend server (https://(backend_server_IP)), the connection worked just fine. I have attached the capture from both the browser and F5. Why is the server resetting the connection requests only from F5? Any insights would be helpful.
Adding captures
I don’t see any captures.
But a common issue is SNI. BIG-IP does not use it by default.
Try to create a specific Server side SSL profile defining the appropriate server name and add it to the monitor.
Of course if it works do not forget to use it also in the Virtual server
Thanks for your reply. I added SNI and still got the same response. I tried to force it to use TLS1.2 as well but it did not resolve my issue.
Could you share you monitor settings and a packet capture?
Have tried the same request with a curl from F5?
Yes, I tried with the Curl command as well. It was reporting “unknown SSL protocol error”. I tried to initiate the connection using the openssl command and tried to force it with different TLS versions (1.0, 1.1, and 1.2) and sent SNI, but still no luck.
SSL handshake only fails for the custom port, but when I initiate using 443, it works fine from F5 (Curl, openssl, and health check).
[Active:Changes Pending] log # openssl s_client -connect x.x.x.x:custom_port -servername example.com
CONNECTED(00000003)
write:errno=104
no peer certificate available
No client certificate CA names sent
SSL handshake has read 0 bytes and written 276 bytes
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
    Protocol  : TLSv1.2
    Cipher    : 0000
    Session-ID:
    Session-ID-ctx:
    Master-Key:
    Key-Arg   : None
    PSK identity: None
    PSK identity hint: None
    Start Time: 1753690172
    Timeout   : 300 (sec)
    Verify return code: 0 (ok)
Hi @nurairtt91
The most likely cause is that the backend server is not running SSL/TLS on the custom port. Can you try from F5:  curl https://x.x.x.x:custom_port
Is that connecting and providing successful response ?
Backend server is connecting on custom port when we tried from the browser (which confirms TLS enabled on custom port), but curl from F5 not getting expected response.
Is there a FW between F5 and Server?
Does this traffic been allowed?
Yes, this traffic is allowed. TCP handshake is successful between F5 and server. Server sends RST after it receives SSL client hello.
Can you share a wireshark capture?
