We are trying to expose our backend application, which is behind a Windows IIS reverse proxy. Based on URL rewrite rules which look for host header and than route the call to the backend.
When trying to open the URL, from inside our network, from another server we get the requested page in firefox web browser.
When trying the same URL from F5 CLI, we also get the expected page.
But when trying from the Internet, we get ERR_CONNECTION_RESET from Chrome and Firefox.
What have we checked?
F5 is doing the TLS termination, and we have a valid certificate in place.
The node and pool are green.
SSL Profile (Server) < serverssl > is assigned because communication to the pool is HTTPS.
Did you take a packet capture? You should see the reason for the reset on the capture.
tcpdump -nni 0.0:nnnp -s0 host X.X.X.X and port XXXX -w/var/tmp/capture.pcap
Enabling these could help as well.
Log in to the TMOS Shell (tmsh) by entering the following command:tmsh
To configure the BIG-IP system to log the TCP RST cause in the /var/log/ltm file, you must enable the TM.RstCause.Log database variable by entering the following command:modify /sys db tm.rstcause.log value enable
Optional: To configure the BIG-IP system to include the RST cause information in the TCP RST packet payload, you must enable the TM.RstCause.Pkt database variable by entering the following command:modify /sys db tm.rstcause.pkt value enable
