Hi, I’ve created a basic pool with a single node configured with port 80 a virtual server also configured with port 80.
The virtual server is enabled and the node in the pool is active.
In the node we have a nginx running in a docker container, we’ve made a port-forward of this service to expose it.
But when I try to cURL to the virtual server the response is:
curl -v http://<vs-ip-addr>
* Trying <vs-ip-addr>:80…
* Connected to <vs-ip-addr>(<vs-ip-addr> port 80 (#0)
> GET / HTTP/1.1
> Host: <vs-ip-addr>
> User-Agent: curl/7.81.0
> Accept: */*
* Recv failure: Connection reset by peer
* Closing connection 0
curl: (56) Recv failure: Connection reset by peer
If I cURL to the node configured in the pool:
curl -v http://<node-ip-addr>
* Trying <node-ip-addr>:80…
* Connected to <node-ip-addr> (<node-ip-addr>) port 80
> GET / HTTP/1.1
> Host: <node-ip-addr>
> User-Agent: curl/8.4.0
> Accept: */*
< HTTP/1.1 200 OK
< Server: nginx/1.25.4
< Date: Fri, 19 Apr 2024 11:09:30 GMT
< Content-Type: text/html
< Content-Length: 615
< Last-Modified: Wed, 14 Feb 2024 16:03:00 GMT
< Connection: keep-alive
< ETag: “65cce434-267”
< Accept-Ranges: bytes
<!DOCTYPE html>
<html>
<head>
<title>Welcome to nginx!</title>
<style>
html { color-scheme: light dark; }
body { width: 35em; margin: 0 auto;
font-family: Tahoma, Verdana, Arial, sans-serif; }
</style>
</head>
<body>
<h1>Welcome to nginx!</h1>
<p>If you see this page, the nginx web server is successfully installed and
working. Further configuration is required.</p><p>For online documentation and support please refer to
<a href=“http://nginx.org/”>nginx.org</a>.<br/>
Commercial support is available at
<a href=“http://nginx.com/”>nginx.com</a>.</p><p><em>Thank you for using nginx.</em></p>
</body>
</html>
* Connection #0 to host <node-ip-addr> left intact
