F5 not sending traffic to Web pool
Hello All,
I am having issues with a new configured F5 big-IP that everything works fine as follows.
  1. traffic from the client is coming to the firewall which is then natted to the private network. (works)
  2. the Load balancer ( Virtual server) IP is accessible and request is sent to the virtual server.
  3. and from the BIG-IP to the pool is not sent.
  4. connection between the F5 to the pool is fine and vice versa and pool and nodes are available (green).
  5. connection between web-server and F5 is through Https (443).
configuration F5 as follows:
F5  Virtual IP : 192.168.1.41
self IP:   int 1 : 10.10.10.14
self IP   int 2 : 192.168.1.41
web server pool :  10.10.10.X  range with class c subnet.
SSL is configured between the client to F5 as clientssl and between the server and F5 as serverssl.
source address translation is automap.
I am having trouble why it doesn’t work and is trying to find out the problem.
If you can provide the associated configuration of the F5 it would help significantly in troubleshooting this issue. How have you verified that connections are not being sent out from the F5 to the pool members? If you could try running the following tcpdump it might point you to the issue.
tcpdump -nni 0.0:nnp host <virtual server IP>
The tcpdump should follow the SNAT that is occurring to see where the connection is not functioning properly.
I captured the tcpdump packet and analyzed it, the request is coming from the client and three-way handshake is done between the client and the F5 but after nothing happens and when I look into the pool statistics nothing is there and it’s all zero.
have captured packets multiple times and checked packet by packet and the connection is RST at last.
apm oauth db-instance /Common/oauthdb {
    description “Default OAuth DB.”
apm policy customization-source /Common/modern { }
apm policy customization-source /Common/standard { }
apm report default-report {
    report-name sessionReports/sessionSummary
    user /Common/admin
ilx global-settings {
    debug-port-blacklist { 47019 54321 60000 }
ltm default-node-monitor {
    rule none
ltm node /Common/f5STGWEB01 {
    address 10.10.10.15
    monitor /Common/https_443
ltm node /Common/web1 {
    address 10.10.10.21
ltm pool /Common/webpool {
    members {
        /Common/f5STGWEB01:443 {
            address 10.10.10.15
        /Common/web1:443 {
            address 10.10.10.21
    monitor /Common/https and /Common/https_443
ltm snat-translation /Common/192.168.1.41 {
    address 192.168.1.41
    inherited-traffic-group true
    traffic-group /Common/traffic-group-1
ltm snatpool /Common/snatpool1 {
    members {
ltm virtual /Common/virtualserver1 {
    creation-time 2024-04-30:17:02:17
    description “virtual server is the load balancer server”
    destination /Common/192.168.1.41:443
    ip-protocol tcp
    last-modified-time 2024-05-08:17:01:47
    mask 255.255.255.255
    profiles {
        /Common/F5SANCert {
            context clientside
        /Common/serverssl {
            context serverside
        /Common/tcp { }
    serverssl-use-sni disabled
    source 0.0.0.0/0
    source-address-translation {
        type automap
    translate-address enabled
    translate-port enabled
ltm virtual-address /Common/192.168.1.41 {
    arp enabled
    icmp-echo enabled
    traffic-group /Common/traffic-group-local-only
ltm profile client-ssl /Common/F5SANCert {
    app-service none
    cert-key-chain {
        f5-F5-With-SAN_SANChainCert_0 {
            cert /Common/f5-F5-With-SAN
            chain /Common/SANChainCert
            key /Common/f5-F5-With-SAN
    defaults-from /Common/clientssl
    inherit-ca-certkeychain true
    inherit-certkeychain false
    options { dont-insert-empty-fragments no-tlsv1.3 no-tlsv1.1 no-sslv3 no-tlsv1 }
ltm profile client-ssl /Common/F5f5 {
    app-service none
    cert-key-chain {
        f5-F5-certificate_F5f5Chain_0 {
            cert /Common/f5-F5-certificate
            chain /Common/F5f5Chain
            key /Common/f5-F5-certificate
ltm profile client-ssl /Common/clientssl {
    alert-timeout indefinite
    allow-dynamic-record-sizing disabled
    allow-expired-crl disabled
    allow-non-ssl disabled
    app-service none
    authenticate once
    authenticate-depth 9
    bypass-on-client-cert-fail disabled
    bypass-on-handshake-alert disabled
    c3d-client-fallback-cert none
    c3d-drop-unknown-ocsp-status drop
    c3d-ocsp none
    ca-file none
    cache-size 262144
    cache-timeout 3600
    cert /Common/default.crt
    cert-extension-includes { basic-constraints subject-alternative-name }
    cert-key-chain {
        default {
            key /Common/default.key
    cert-lifespan 30
    cert-lookup-by-ipaddr-port disabled
    chain none
    cipher-group none
    ciphers DEFAULT
    client-cert-ca none
    crl none
    crl-file none
    data-0rtt disabled
    generic-alert enabled
    handshake-timeout 10
    inherit-ca-certkeychain false
    max-active-handshakes indefinite
    max-aggregate-renegotiation-per-minute indefinite
    max-renegotiations-per-minute 5
    maximum-record-size 16384
    mod-ssl-methods disabled
    mode enabled
    notify-cert-status-to-virtual-server disabled
    ocsp-stapling disabled
    options { dont-insert-empty-fragments no-tlsv1.3 }
    passphrase none
    peer-cert-mode ignore
    peer-no-renegotiate-timeout 10
    proxy-ssl disabled
    proxy-ssl-passthrough disabled
    renegotiate-max-record-delay indefinite
    renegotiate-period indefinite
    renegotiate-size indefinite
    renegotiation enabled
    retain-certificate true
    secure-renegotiation require
    server-name none
    session-mirroring disabled
    session-ticket disabled
    session-ticket-timeout 0
    sni-default false
    sni-require false
    ssl-c3d disabled
    ssl-forward-proxy disabled
    ssl-forward-proxy-bypass disabled
    ssl-forward-proxy-verified-handshake disabled
    ssl-sign-hash any
    strict-resume disabled
    unclean-shutdown enabled
ltm profile client-ssl /Common/mynewcertificate {
    app-service none
    cache-size 262144
    cache-timeout 3600
    cert-key-chain {
        MyCertificate_0 {
            cert /Common/MyCertificate
            key /Common/MyCertificate
    cipher-group none
    ciphers DEFAULT
    data-0rtt disabled
    mode enabled
    proxy-ssl disabled
    server-name none
    sni-default false
    sni-require false
    ssl-sign-hash any
ltm profile server-ssl /Common/do-not-remove-without-replacement {
    app-service none
net dns-resolver /Common/f5-aws-dns {
    forward-zones {
        amazonaws.com {
            nameservers {
                8.8.8.8:53 { }
        idservice.net {
            nameservers {
                8.8.8.8:53 { }
        shpapi.com {
            nameservers {
                8.8.8.8:53 { }
    route-domain /Common/0
net dns-resolver /Common/internaldns {
    forward-zones {
        dns {
            nameservers {
                192.168.1.11:53 { }
                192.168.1.12:53 { }
net route /Common/default {
    gw 192.168.1.1
    mtu 1500
    network default
you can have decrypted tcpdump using this procedure which the result will be useful for analysis
even with non decrypted tcpdump, wireshark can show tls session setup sequence.
at least in old version, health monitor uses management layer’s network routing, which is different from what ltm traffic uses.
so, health monitor OK doesnt always mean ltm traffic can reach backend server.
Can you please check the routes? As I can see, there’s only one route default route for 192.168.x.x  Can you also check? Do you need any more routes for 10 dot subnet  for the internal interface
can you also check that you’re using auto map in your VIP,   you can try SNAT , so could you please try apply SNAT ?
what route path normally ltm uses and how it makes the packet route decisions? if you could elaborate more on that.
I tried SNAT as well and it did not work and there is only one route that I can add is the default route which I have added and I can not add a route for 10.10.x.x because it has a direct connection to it which is normally the self IP.
the data plane uses routing config from the webgui Network tab
If client ip should be transition and is not routable THROUGH the bigip you need SNAT activated with automap (than it uses float ip in HA or selfip in standalone) or you configure a snat pool
If i see this correct, you give your virtual server the same IP as your pool member?
