What does it mean when the LCD display shows “Blocking DoS attack”? I found the following F5 Manual at the Ask F5: 404 Page not found | BIG-IP Documentation Any other situation the BIG-IP would show this message on the LCD display?
Hi Willian,
can you check your logs for f5 if they are indicating anything . This link might be useful . 404 Page not found | BIG-IP Documentation
You can also try to reboot the device might be some memory issue or device for many days .
Also you can try to clear alarm : 404 Page not found | BIG-IP Documentation
But make sure if this is real attack or something wrong/config with the F5 .
you own link explains it all, the Adaptive connection reaping kicked in. via your logs and the value before the message will tell you when it happened. but as mentioned in the information, it doesnt have to be a DDOS, it is memory related, so you could just also be low on memory due to heavy load or memory leak.
