Not sure if I’m posting this in the correct forum, apologies if not.
We have an Active/Standby cluster of 2 F5 Bigip 1600’s running 9.4.7.
Recently we noticed the Standby F5 is displaying the following error on its LCD display:
“Critical: 9d Blocking Dos Attack”
[I’m assuming “9d” refers to 9 days because the number increases each day].
Is there anything I could or should be doing about this? I’m assuming this just means its doing its job and blocking a denial of service attack, however if I log into the web interface of the device there is nothing in the logs to indicate there is anything going on [I cant find any reference to a Dos attack].
The Active cluster member isn’t displaying any errors [so I guess its targeted at the local IP address of the external interface of the Standby member?]
Should we just wait this out or can something be done about it? As far as I can tell its not affecting our network in any way [although we are having a weird problem with the VPN tunnels on our firewall cluster, but I think thats a coincidence].
Thanks in advance
I found these links on a post Hoolio had responded to back in 2011 that might help. The error is triggered when LTM runs low on memory. I suspect the standby is running low on memory due to a code bug and I’d suggest a reboot might fix this issue;
sol4611: Overview of adaptive reaping
sol7301: Protecting the BIG-IP LTM against denial of service attacks
Thanks for the reply, I have rebooted the device and the LCD display error message has indeed been cleared [LCD has returned to normal and is displaying statistics, etc] but the red alarm light is still lit on the front of the box.
Still cant see anything in the web interface regarding what the alarm might indicate. Do you have any suggestions for resolving this issue?
Is the Status LED green or yellow, solid or blinking?
The status LED is solid yellow
OK, so that’s normal. So nothing in the logs on the device that indicates an issue?
In the System>Logs menu, the “System” tab shows “Configuration reload request received, reloading configuration” three times, the “Packet Filter”, “Local Traffic” and “Audit” tabs all show “No records to display”.
The ‘configuration reload’ message is normal. I assume there’s no error being displayed (that can be cleared/acknowledged) on the LCD? If not, I assume this is a bug. What version are you running?
It might be worth checking memory levels and actually checking connection levels to ensure there isn’t a real issue.
The version is “BIG-IP 9.4.7 Build 320.1 Final”. The LCD is not displaying any errors, just displaying statistics about memory, etc.
The System memory shows: Host total=3.4G, Host Used=3.3G, TMM Total=2.7G, TMM Used=45.1M
Active connections is steady at around 1.25k.
I tried that advice however the problem remained, I then found 404 Page not found | BIG-IP Documentation
which advised using the clearlcd_warning command, which worked! The alarm is now cleared.
Thanks for your help.
Excellent, thanks for sharing that. You’re welcome.
Question:
My customer wonders as to whether or not this message “Blocking DOS attack” is being logged somewhere (either in local logging on F5 LB or in remote/system logging, if set up).
Could you please respond by tomorrow at latest ? Thanks
