We are using BIG-IP 15.1.3.1 . We have an application that uses a JWT auth scheme. However the f5 keeps overriding the Authorization Header containing the Bearer. Is there an I rule that we could write to prevent that from happening. Thank you
you can probably write such an iRule.
but i would start with why does the BIG-IP override that header?
is this a normal virtual server or are you using APM or such?
