F5 Insight for ADSP – Initial Setup in VMware
Table of Contents
Demo Video
Initial VMware Configuration
Download the ova file from myf5.com.  In VMware choose the Create/Register VM option and choose Deploy a virtual machine from an OVF or OVA file.
Continue through the install wizard, which will upload the ova file to your VMware server.  Uncheck the option to Power on automatically so you can edit the VM properties prior to boot.
Note: Thick Provision Lazy Zeroed is recommended for performance
Edit the Virtual Hardware options and set the hardware settings as follows:
Note: A 600 GB disk formatted to Thick Provision Lazy Zeroed is recommended for performance
Switch to the VM Options tab and expand Advanced
Scroll down and click Edit Configuration
Click Add parameter and add the following:
guestinfo.userdata.encoding = base64
Create a local cloud-config.yml file to set the administrative username and password:
Be sure to change the admin password and make a note of it.  Then you need to base64 encode the file.
Return to the VMware Configuration Parameters screen and Add another parameter named “guestinfo.userdata” and paste the base64 encoded text in the Value.  Click OK when done.
After saving the VM settings, you are ready to power on your VM for the first time!
Note: Refer to the F5 Insight on VMware Deployment Guide for further details on this procedure.
Post Boot VM Settings
Open the VM Console and login to F5 Insight with the credentials specified in the cloud-config.yml file
Configure the F5 Insight network settings using the following commands:
Example:
After hitting Enter, you will see the following:
If no changes are needed, enter “y” to confirm.  The output should look like the following:
Note: Refer to the F5 Insight User Guide for further details on this procedure.
Accessing the User Interface
The initial configuration is complete and you can now log into the UI.
You will see the Welcome screen. Click Next.
Paste the text of the JWT Token and click Validate.
If the license is activated, click Next.
Enable the LLM Provider.  Select your LLM Provider, Anthropic in this example.  Enter your API Token/Key and the Enterprise API URL.  Note that I am skipping TLS verification.
Click Test Connection.
Click Next if the test is successful
On the next screen, select your preferred Setup Method.  I’m using Start Fresh.
Click Add Device
Enter the Endpoint, Username and Password
You can optionally configure a Certificate Authority and Data Center
Select the Modules that are active and you want to monitor.  Click Add Device.
Click Next
The configuration is complete.  You can view the Home Page or the Device Settings.
The Home Page should look like this:
Conclusion
F5 Insight for ADSP offers customizable visualizations and dashboards to help teams surface actionable metrics and KPIs tailored to your organization. It provides access to useful telemetry data for a deeper understanding of your environment, application behaviors, and complex BIG-IP deployments, all centralized in a single location.
  • Identification of root causes during outages/tickets.
  • Solve issues and struggles with Day 2 analysis of your BIG-IP Fleet and the applications therein.
  • Mitigates the problem of a lack of detailed visual information on your BIG-IP Fleet.
  • Set a foundation for the utilization of open-source tools and their benefits.
Introducing F5 Insight for ADSP
F5 Insight for ADSP - A Closer Look
F5 Insight for ADSP Documentation
F5 Insight Product Page
F5 Insight Release Blog
