What’s new in F5 Insight for ADSP v1.1?
Table of Contents
Introduction
F5 Insight for ADSP, a key component of the F5 Application Delivery and Security Platform (ADSP), helps teams monitor and secure apps that are spread across hybrid, multi-cloud and AI environments. In this article, I’ll highlight some of the new features introduced in F5 Insight v1.1.
Demo Video
Disaster Recovery
Now with enhanced User Workflows.
The F5 Insight Disaster Recovery feature helps your system keep running even if one server fails. It works by maintaining two synchronized systems:
  1. Primary instance — Handles all active operations.
  2. Standby instance — A backup system that continuously syncs data from the primary.
If the Primary fails or requires maintenance, you can “promote” the Standby to take over as the Primary. After fixing the first system, you can perform a “failback” to restore it to normal operation.
Change to Default User Credentials on First Boot
F5 Insight now supports a default user and random password login workflow. You can either use cloud-init (like previous version) or the default user credential option.
NOTE: This applies to new installations, not upgrades.
In previous versions of F5 Insight, the procedure to set the admin username/password involved utilizing the “cloud-init” function.  There is now an alternative method for setting the admin username/password.  A unique password will be generated at first boot, allowing administrators to log in for the first time using this password.
This randomly generated password must be changed after initially logging in.
UI Improvements
Previous versions of F5 Insight dashboards with large data volumes could experience some performance degradation due to extensive configuration objects.
This has been resolved by implementing comprehensive performance optimizations across the dashboard platform, enabling it to handle significantly larger datasets while maintaining a fast and responsive user experience.
Upgrade Procedure
You’ve probably never upgraded your F5 Insight version, so it’s time to learn how.  First, download the updated software version from myf5.com.  The updated software is distributed as a bundled gzipped tar file.
Then, upload the new version to your F5 Insight from the About screen, then click Upgrade.
After uploading the new version, select Start Upgrade.
The upgrade will take several minutes.
Conclusion
The latest version of F5 Insight for ADSP offers expanded functionality with Disaster Recovery.  It also provides a convenient alternative to “cloud-init” for setting the initial administrative username & password.  Finally, there are several UI improvements aimed at making the user experience better and more seamless.
Upgrade today to the latest version of F5 Insight for ADSP and enjoy the following benefits:
  • Streamline the initial configuration of F5 Insight with the new default admin user and dynamically generated password.
  • Enjoy expanded workflows with the Disaster Recovery feature.
  • Benefit from the many UI improvements.
Introducing F5 Insight for ADSP
F5 Insight for ADSP – Initial Setup in VMware
F5 Insight for ADSP - A Closer Look
F5 Insight for ADSP Documentation
F5 Insight Product Page
F5 Insight Release Blog
