F5 Http Health Monitor check truncates response
I configured a http health check on F5 and the request gets a rather large response, but if I perform the request manually from the browser it works.
But on F5, I configured the “Receive String” to check for the contents in the end of the response, and the health check is failing.
I used tcpdump to inspect the traffic on the target I could confirm that the response is truncated (F5 closes the connection before it ends).
Is that a bug? Or is it an expected behavior?
Thank you
Receive string must be found in the first 5,120 bytes of the response.
As Tim says this is expected behavior. If you need to monitor for a string beyond the 5k limit an external monitor could be used. See SOL3451
