health monitor that worked in 10.0.1 failed with 10.2.1
Hi All,
With 10.0.1 code, a health check that checks for http GET requests and receive “200 OK” passed with no problems. When the code was upgraded from 10.0.1 to 10.2.1, all servers that had this health check were marked down causing an unexpected outage.
I run the same health check on the F5 CLI by doing telnet to port 80 on the server and sending the same GET request and I get a “200 OK” response.
I am not sure what the problem is. I increased the timeout but the problem is not due to the timeout.
Meena
Hi Meena,
In 10.2.0, bigd behavior was modified to not append any \r\n’s to the end of the monitor send string for HTTP, HTTPS and TCP. If you add two \r\n’s to the end of the send string does the pool get marked up?
See SOL10655 for details:
sol10655: Change in Behavior: CR/LF characters appended to the HTTP monitor Send string
Aaron
Aaron,
I played around with it adding and removing extra CR and LF but cannot bring up the pool. The only work around I have to bring up the pool and the web page is to remove the check for receive string. Tcpdump shows 200 OK string on the response and I have no idea why it fails. I modified the receive string to exactly match the case etc.
The same monitor works fine for the same servers from Big-IP running 9.4.7 code. When I run the same GET request on the Big-IP CLI (Linux OS), it works fine. It is just the TMOS version 10.2.1 that is having issues.
Meena
Can you post anonymized send and receive strings that were working in 9.4.7?
Aaron
This is the monitor that works in 9.4.7 and 10.0.1 but does not in 10.2.1.
GET / HTTP/1.1\r\nHost : 10.22.0.192\r\n and the receive string is 200 OK.
GET /login.asp HTTP/1.1\r\nHost: 10.22.0.196\r\nConnection: Close\r\n and the receive string is 200 OK.
I added extra and removed \r\n but nothing seems to work.
Meena
Can you try this:
GET /login.asp HTTP/1.1\r\nHost: 10.22.0.196\r\nConnection: Close\r\n\r\n
And then start with a receive string of HTTP. If that works, then try 200 OK. If one or both don’t work, you can try the steps outlined here to troubleshoot the issue:
http://devcentral.f5.com/wiki/default.aspx/AdvDesignConfig/TroubleshootingLtmMonitors.html
or here:
Aaron
Ok. I tried this and it is working.
GET /login.asp HTTP/1.1\r\nHost: 10.22.0.196\r\n\r\nConnection: Close\r\n
and the receive string is 200 OK. Thanks Aaron.
Meena
That wouldn’t be a valid HTTP request as the double \r\n would terminate the request and then you have another HTTP header appended. Can you try it like this:
with a receive string of 200 OK?
Aaron
Yes. I tried that and it is also working.
Hi Meena & Other experts
I have been using the below string in 10.1 for http service monitoring. But on 10.2 its not working. Any idea how i should be modifying the string?
GET /CAI3G1.1/services/CAI3G1.1 HTTP/1.0\r\n
and no receive string 200 OK. used in 10.1.
I have tried the below and receive string as 200 OK. still not working.
GET /CAI3G1.1/services/CAI3G1.1 HTTP/1.0\r\n \r\n
any help would be much appreciated.
Thanks a lot in advance.
//Sujan
Hi Sujan,
Looks like you might have a space character between your two \r\n sequences? Can you remove that and try again?
Thanks,
Jen
I am also facing same issue
old F5 having firmware BIG-IP 10.2.0 Build 1789.0 Hotfix HF2 - 6400
and not working on New BigIP 6900: BIG-IP 10.2.4 Build 655.0 Hotfix HF4
send string : GET /exploit-mag-csg/ HTTP/1.1\r\nHost:bfc.saint-gobain.com\r\nConnection :Close\r\n\r\n
receive string: 200
monitor is marking node UP in OLD F5 but marking DOWN in New F5
OLD: 6400 and NEW: 6900
can you pls suggest
Kalpesh,
Did you try move the space after colon instead of before for Connection eg GET /exploit-mag-csg/ HTTP/1.1\r\nHost:bfc.saint-gobain.com\r\nConnection: Close\r\n\r\n
